NRamaswami
Oscar:
I think the Lenz law effect is present in motionless systems in the form of backemf.
Earlier in a solenoid I had a quadfilar primary and a single wire secondary. Both are 4 sq mm. 220 volts and 50 Hz. The quadfilar consumed 220 volts and 15 amps. The secondary produced 300 volts and 10 amps on load. The solenoid was iron core.
I can use a Neon lamp in the primary and use a fast charging and discharging RUN capacitor in series and slow charging and discharging capacitor in parallel along with high ohm resistor in series. Neon lamp is a spark plug and so will increase the frequency. Please provide the ratings for the capacitor in series and capacitors in parallel. I can test the device and find out in practical experiment what is the value of frequency and whether the Lenz effect is there or not.
High frequency is said to heat up the Iron core and so the core will have to be much bigger than at lower Hertz.
Low frequency may not be as efficient as high frequency for the same reasons you provide and Low frequency at 8 to 10 Hz can also resonate with Earths magnetic field and can cause health problems as well. A high voltage line carrying 50 or 60 Hz is said to cause cancers to people living near the line and constructing buildings are prohibited near high voltage power lines for this reason.
Aircraft are said to use 400 Hz but beyond that the wires and the iron core are said to heat up. But I really do not know the answer to this question and I can test and find out high frequency has on input and output. I do practical experiments and then find out and do not accept theoretical statements from any one.
It is possible that high frequency can cause the core to heat up very much and so much larger core may be needed. In so far as the rotary device is concerned if we increase the number of contacts to 100 then for one Revolution per second we have 50 Hz output or for 60 RPM we will have 50 Hz and by increasing the number of contact points or by increasing the Revolutions or by increasing both we can increase the frequency. It is not difficult to do. A spark plug cum resistor in series and a capacitor  in series and in parallel combination can do it much more easily.
Please provide the capacitor values and let me test and tell you the results.  Thank you. I do not accept theoretical statements and test and find out.
marathonman
 Quote; "had to concede that the quadfilar wire is capable of saturating the core".
Sorry to spoil your parade but i Never said that as any one know with enough currant it will saturate a core.
also the statement about 7 hz being dangerous....you need a little more study in that area as this is incorrect.
also your statement about 400 hz is incorrect as some planes use up to 2800 hz again you need a little more research in that area as the use of high frequency allows for reduced size transformers.
Quote; "I think the Lenz law effect is present in motionless systems in the form of back emf".
This is absolutely correct as the declining electromagnet puts energy back into the system in the rotating part G of his system as i was so informed. see Figuera did not side step  lenz's law he counted on it to feed energy back into the system in the form of stored magnetic energy in part G from each electromagnet in the declining phase. as each electromagnet declines it feeds energy back into the system to replace only the losses though heat and wire loss which is very little.
the use of diodes will not let the system feed energy back into the system it block it.
MM
ignacio
Bueno, a ver si me se explicar:
La electricidad viaja, en un solo sentido, (hay o no hay). ¡!!La ca sigue la electricidad, viajando en una sola dirección!!! Solo que, en un momento, viaja en una, y luego viaja, en la otra dirección. El problema es la que llamamos "negativa", (al igual, el frió no existe, solo existe la disminución de calor, o disminución de vibraciones)
>>"todos" los aparatos de esa generación, que dan sobre unidad, se basan, en que se alimentan los (electroimanes) inductores, con una señal de corriente, en un único sentido, (ya que la c. alterna, va en ambos sentido, se ha de separar, cada dirección, para cada modulo (modulo = 2 electroimanes 1 inducida) (no electroimán de cada modulo).
>>Si usamos dos electroimanes, mientras uno atrae (con electricidad en una dirección) la inducida, la otra esta al mínimo, luego el electroimán opuesto (con la misma dirección de electricidad) atraerá la inducida, (eso debe estar claro). Así se evita, que haya que esperar la orientación del núcleo, produciendo calor, en él (cocinas de inducción).
>> Según el voltaje que usemos para alimentar: tenemos que con 12v 4amp =48watt, con 48v solo 1amp =48watt y si con 110volt 0.436amp = watt
Según el amperaje, solo pongo el de 110volt a 3amp =330watt ) con un reóstato se puede regular, subir y bajar el amperaje (yo con dos vasos de agua)
>>Viendo unos dibujos antiguos, que tenia guardados, donde se resalta la diferencia de la onda de C. F. y la semi-onda de corriente alterna (usando solo una dirección de la corriente) se puede observar, que la onda de C. F. es bastante más eficiente, que la semi-onda de ca.
Pongo el dibujo. Que sea más eficiente, no quiere decir, que no funcione con la semi-onda.
Well, see if I explain:
Electricity travels in one sense (to be or no to be?). !AC The electricity traveling in one direction! at one point he travels in one direction, and then travels in the other direction. The problem is what we call "negative" (as the cold does not exist, there is only the reduction of heat, or decreased vibration )
>> "All" these devices of this generation, which give over unity, they are based on the (electromagnets) feed inductors with a current signal, in one direction, (since AC, It goes both ways, They must be separated, each direction, in each module (1 induced electromagnets = 2) (not electromagnet of each module).
>> If we use two electromagnets, while one you attract (with electricity in one direction) induced, the other, this the minimum, then the opposite (same address electricity) induced attract electromagnet (it should be clear). This prevents, it will have to wait the orientation of the core, generates heat, it (induction cookers).
>> According to the voltage we use to power: we have with 12v 4amp = 48w;; 1 amp 48v =48watt; and if with 0.436amp 110volt = 48watt
Depending on the amperage, just put the one to 3amp 110volt = 330watt ) with a rheostat can be adjusted, raise and lower the amperage (I with electrodes on two glasses of water)
>> Viewing some old drawings, which had saved, where the difference wave CF is highlighted and the half-wave of alternating current (using only one direction of flow) it can be seen that the wave of CF is much more efficient, that the half wave of ca.
I put the drawing. Make it more efficient, does not mean not work with the semi-wave.
I hope I explained
:'( :P :'(
ignacio
Soy persona rural, agraria, sin cultura científica, un burro.
Soy un charlatán.
I am a rural, agrarian person without scientific culture, a donkey.
I'm a charlatan.
marathonman
It has nothing to do with half wave at all. Figuera's devise is using DC so there is no phase BS to deal with. he simply takes one electromagnet up as one is taken down to compensate for the loss of one very strong AC wave plain and simple because the declining electromagnet is still adding to the gaining electromagnet in the form of feeding the system. if your intelligence  can't handle that well i can't help that as that is your demon not mine.
just because you made it work doesn't mean it is efficient as it can be, yes you have it working but not Figuera style. you still haven't included ANY research to back it up just conjecture so i guess we are equal in that aspect. Diode block the recharging of the system that is why it is self sustaining ie... BOTH electromagnet working in unison not separate.
go ahead and keep your Diodes i applaud you but i will keep mine.
