0 Members and 23 Guests are viewing this topic.
ignacio
NRamaswami:
Al usar 220 volt con series de bobinas (7bobinas) cada bobina, recibe ~ 31.4 volt si usas 110 volt (ok) ~ 15.7 cada bobina, con diodos esta bien.
By using 220 volt with series of coils (7 coils) each coil receives ~ 31.4 volts if you use 110 volt (ok) ~ 15.7 each coil, diode is good.
Question draw:
batfish
This may be clearer: 2 sets of inducer pairs with 2 diodes per set:
[[N a1, Sa1],[N a2, S a2]]
[[N b1, Sb1],[N b2, S b2]]
The inductance is not significant - this is just to illustrate a possible arrangement.
Batfish
marathonman
Yes Hanon variac's can be used with DC but to save confusion just call it a Rheostat that uses the magnetic field in the core (reluctance) to control the amperage NOT RESISTANCE.
Figuera did not have to use Diodes and would not of because they will block the energy being put back into the system. basically he did it the smart way using magnetics to control amperage.
it doesn't matter any way's even if the information was on the faces of people they would wipe it off and try something else. good luck you'll need it
ignacio
Lo entiendes, es tu diseƱo.
you understand ? this is your design.
marathonman
Good God your stupid, i guess when God said brains you thought he said trains and yelled ! "I want a slow one"
Ya'll successfully fucked off a good forum that had posted enough information to get a working device..... then came STUPIDITY !
have fun Dumb asses with your third world tech support and circuits....ha ha ha ha !
