tak22
marathonman, you've crossed the line for no supportable reason.
please modify your last message, and think a little harder before you post next time. thanks.
tak
NRamaswami
Quote from: ignacio on March 21, 2016, 01:14:30 PM
NRamaswami:
Al usar 220 volt con series de bobinas (7bobinas) cada bobina, recibe ~ 31.4 volt si usas 110 volt (ok) ~ 15.7 cada bobina, con diodos esta bien.
By using 220 volt with series of coils (7 coils) each coil receives ~ 31.4 volts if you use 110 volt (ok) ~ 15.7 each coil, diode is good.
Question draw:
Ignacio:
No  Patent will disclose full details.
From my experiments I already know that Parallel connected opposing Primaries in NS-NS-NS configuration work best.
While you divide the voltage with series connection for parallel Connection The voltage is not diminished. Consequently the output is higher. If you were to use AC we can use multifilar thin coils 10 to 12 in number and reduce amps drawn. In Pulsed DC the only thing that Counts is resistance of the Coil and frequency . So before Current enters the electromagnets you need to increase the frequency and frequency if possible.
Both of these things are done if you use a None Lamp that will light up at 220 volts and a big resistance coil of No. 30 to 35 AWG Kg coil properly wound as the array shown in Figuera Patent. You give this to the Primary as input and let the Primary ends to go to the ground.
Now the current drawn is very low and if you connect the secondary in series using thick wires the output of secondary will be far higher. You can easily get this.
The feedback coil comes from secondary and the phase is changed using either a capacitor or transformer to make the output exactly about 220 volts. Use a Metal oxide Varristor and a 0.5 Amp fuse to control the current and the voltage and give it again through a high resistance coil and neon lamp. The Diode Bridge is to be used to make the current full positive sign wave current. Since the current always flows in this method the full positive sign wave will always be above zero and a collapsing magnetic field is actually prevented.
Lenz Law is said to be absent when the magnetic field is not allowed to collapse and this happens in this kind of arrangement. But for that you need to use Diode Bridge. A half wave with diodes will result in the magnetic filed to collapse.
Using this method it is possible to produce electricity with a one time input to start the system and then the system will always run automatically until the components wear out. Then they have to be replaced and then the system can be again restarted.
Reducing the amperage reduces heat. Increasing the frequency increases heat. Therefore the core must be not a single iron piece but a lot of rods. Then it beoomes aero iron core where the air between the iron rods can hold a lot of magnetic field and the strength of the magnetic field becomes very high. The heat in the iron rods makes the cool air from the environment to flow in to cool the air and more ionized air moves out and air continues to circulate cooling the iron.
This core will work for any frequency. There is no need to make it above 25000 hertz for the output would be very high in the secondary. The pulsed DC output of secondary has to be made pure DC and then inverted to 50 Hz or 60 Hz AC using Inverter.
Here you can use the Primary core and can wind the coils under the primary and above the primary to reduce the size of the device. To prevent saturation of the core the Primary cores need to be much bigger in diameter and longer than the secondary core.
Please see the attached circuit.. Hand drawn..Not yet tested This circuit is the one that would ensure production of electricity in any part of the world. This has been hushed up for it will make many countries with poor population to grow rich very fast and not be dependent on fossil fuels or grid connections.
The Tariel video shows the two earth connections and the earth connections can be avoided and are not needed.
I have not yet tested the circuit. We await funds and electrical engineers. But it will work.
Let me know if you have doubts.
Doug1
 Seems to me running off mains power is not a good test of something that is intended to run itself. No matter how efficient it may be it is still dependent on the grid.I might even question if it is not just drawing excess power from customers nearby through the earth ground. If it were only one connection say the ground for safety that would be more reasonable.even then it might be arguable.
  Since your last step was to think about how you are going to make it work so it can be unconnected seems likely the first few steps might be such that it is too far removed from the principle for that to work. If you can use a gas powered portable generator and double the output that would be something useful as an improvement of portable generators. At the very least you would have a actual generator of electrical power in hand to study what a generator is. If you can use stored battery power and recharge that battery while running useful loads so it can start again later free from the grid that would be more to the spirit of the invention. A generator free of a rotating field magnet with a rotating or changing  field is an extraordinary notion and an impossible one if you do not know how a generator works in first place. If it is that easy to forget all the functions in a generator with a rotating magnet then make a list on paper and pin it where you have to look at it all the time until it is invading you dreams when your sleeping. The only thing being removed from the standard is the physical spinning of the magnet everything ells still has to exist and work properly. If your goal is to build some type of transformer of mains power I think that has been done and in use regularly everyday without so much as a thought.
NRamaswami
Thanks for the constructive criticism Doug:
We can simply use a single Earth connection or two earth connections both not being tied to the grid in any way or No Earth connection.
I have not shown a No Earth connection as it is vastly confusing and needs to be tested. I believe it will work but belief or principle is one thing and experimental result is another thing. Experimental results always triump over what we feel. Presently I'm building a device based on McFarland Cook and Figuera and Hubbard and Cater Hubbard device Combinations as modified by me as needed based on several experiments. Do not know if it will run on its own. In that device there is no earth connection. The iron is oscillated once and it continues the vibration and due to that oscillating electromagnet the secondary coils produce the output. I will test it first and then decide about  posting it based on results.
With all my limited knowledge of what is a Generator or what is a battery I have to beg to disagree with you. The Tesla Radiant Energy Apparatus patent is a Generator. All it needs to be activated is a High voltage, High Frequency spark to hit the plate continuously. This is what the Tesla coil does. If we combine both we have a generator. Both of them have separate ground points. Can we say that Tesla was stealing energy from the grid when the grid as such was non existent. We can say Tesla was stealing Energy from the Earth and Environment and it would be correct but No body owns the Telluric Current and Static Electricity in the Atmosphere. So it is again not stealing really. I showed the prototype of the device under construction without Earth connection to one very knowledgeable person on the forum and he elected not even to discuss that and did not want to be part of that in any way. That was a confirmation to me that the device would work. Let me test and see.
I'm really amazed by the refusal to accept the simple reality. Here the High Voltage lab professor refused to accept the voltage between two different earth points for the Learned professor claimed earth being neutral there cannot be any voltage between two different earth points and that they would consider it a shunted coil but are willing to accept that 20 amps of amperage was flowing in the shunted coil. How can the Volt meter show the difference in that case?
I have made a two separate ground connections which are not connected to the mains. If the ground used is the mains ground your argument is valid. If the ground point is a dedicated non mains ground point there cannot be any drawing of current from the Grid or stealing of current. So to avoid all confusions I'm making a no ground device. While lights will light up would motors run on that. We need to test.
Either Figuera was Right in creating a motionless Generator or You are right that it does not and cannot work like a generator. Secondly the input needed would be only for one instant and not a continuous one. Continuous charging of batteries should be possible but batteries suffer from charging rate and discharging rate problems. So batteries can be replaced by capacitors and they can power the inverter to provide the proper frequency output. Inverters and batteries do provide output when the power goes out.
Not knowing much of Technical stuff I have to end up splitting my hair what is a Generator and what is not? One Professor said no Technical person would accept any thing that can be considered a violation of laws of physics as interpreted by them or their professional growth is gone.
I promised to get this knowledge that if I get this knowledge I would make it public domain so all can use it. I believe I have lived up to that promise. The No ground connection device is there but I need to test it before making any statement.
Even this self looping circuit is yet to be tested but I have seen higher amperage and higher voltage being produced in secondary than the primary and so I'm confident that this would work.
I'm grateful for the constructive criticism.
massive
Quote from: NRamaswami on March 22, 2016, 01:55:30 AM
^^ this is a fact that gets past the majority of researchers .
one more name that needs to be added to motionless generator list is German captain Hans Koler but again the info released is useless . Koler ran his house with his generator .
there is voltage difference between clouds and earth all day long , this was studied in the 1800s . I wouldnt be surprised if Bose did research into telluric currents
good luck with your research
