darediamond
Quote from: NRamaswami on March 23, 2016, 02:54:43 AM
@Forest, Massive..Thanks for the kind words.
It really amazes me that in this forum where people are supposed to do experiments and share their results with an open mind. We are not getting that kind of info unfortunately.
Electricity comes in Electromagnetism by oscillating or vibrating a magnet core and coils are wound around the magnetic core. It simply means that as long as the magnetic core is not static but vibrating or oscillating electricity is going to be produced. Whether that Electricity comes from Sun, Moon, Mars, Jupiter or Earth or Atmosphere we really do not know.
Every atom has a North Pole that contains a part of south Pole and a South Pole that contains a part of North Pole. What we see as Magnetic core is only a conglomeration of billions and billions of Magentic core atmos or molecules. No one knows where the current is coming from and how it is produced. When a conductor is subjected to time varying magnetic field, electricity is induced in the conductor is the Rule. We need not worry as long as it comes.
Open air cores work with high frequency currents. They work very well if the insulation is thicker. It beats me how thickness of insulator plays a role in electrical output. I do not understand it but that is the observation consistent observation made by me and made by others.
Majority of information about these coils are to put it mildly misleading.
When Wright Brothers wanted to fly an airplane they were considered crazy. Sending a satellite to orbit the Earth was considered impossible. Humanity has done it and once the imaginary impossibility is broken many fast developments have taken place in all fields.
Probably I had been chosen to give this information for I'm in no way connected with science and my growth does not depend on what I write whether it is consistent or not consistent with theories. I really do not know why a few people from other countries sent funds to me and asked me to continue with the Research. It again beats me why Patrick took so much of time to teach me through emails.
In 1871 McFarland Cook made the self oscillating device. But the patent provides patently partial information. It seems to be subtantially edited. I feel that I can just use  coils of wire alone and do the device but it is risky. So we need to provide for the safety features.
So this is the real task..
When a conductor is subjected to time varying magnetic field, electricity is induced in the conductor is the Rule. We need not worry as long as it is oscillated continuously. Ultra fast switch on and switch off circuits with capacitors or coils arranged as capacitors must then store the energy for continuous vibrations and the only thing needed is to start it.
I'm really sorry to say that not many here appear to do real experiments or make observations and share results. I do. This is the reason for my confidence.
One thing you should know is that The Members Of Committee Of 300 hates this forum and the only possible means to keep people away from the hidden secrets which people like you have been  exposing o this website is to infiltrate this platform wit there machineries which are trained to provide wrong information.
The first step to kick out Lenz is: Clockwise and Counter-clockwise Winding. ANYONE
WHO DOES NOT WANT TO BE IN BONDAGE OF THE COMMITTEE OF 300 SHOULD NOTE THIS.
Now another rule: YOU MUST ALWAYS WIND YOUR COIL BE IT PRIMARY OR SECONDARY IN SPIRAL BECAUSE IT ONLY TYPE  OF WINDING THAT ALLOWS FOR ONE WAIT DIRECTION WINDING IN ALL LAYERS. WHICH MEANS YOU WILL BE ABLE TO WIND ANTICLOCWISE FROM OUTSIDE TO INSIDE IN ALL LAYERS IF YOU SO DESIRE OR ORTHERWISE IF YOU SO DESIRE TOO.
3. YOU MUST MAKE YOUR SPIRAL COIL TO BECOME A CAPACITOR BY GLUEING WINDING IN EACH LAYER AND FURTHER SEPARATE EACH LAYER WITH A SUITABLE DIELECTRIC. THE
USE SERIES CONNECT CT 4 TWISTED STRANDS AND ABOVE TO MAKE YOU PRIMARY. AND YOU MUST MAKE SURE YOUR PRIMARY WIRE IS THINNER WHICH YOUR SECONDARY IS THINNER.
FOR THE BEST PERFOMANCE, USE SERIES CONNECTED TWISTED THICK COPPER WORKS TO WIND YOUR SECONDARIES ALSO.
HIGH FREQUENCY IS A MUST TO ATTAIN OVERUNITY BECAUSE IT WHAT REDUCES YOUR PRIMARY INPUT AND THE HIGH  INFLOW OF AIR BASE ELECTRICITY IN TO YOUR PULSED COIL.
I think the best configuration is to switch at low voltage using Pure Sine Wave Variable Frequency Driver like the one sold on www.aliexpress.com and step up the pulsed low voltage with a t
Center-tap transformer.
If you can not easily build a 100% Practically Collapsible Multi-Function Twisted MULTIFILAR Wire Coil Winding Machine like mine as shown in the image, at a few Thousand Dollars, I Will Make and Ship one to you Wherever you are in the World.
You need not stress yourself manually twisting Coil like Sir John Bedini used to.
Just cut the check and I make a better looking and high powerful one for you.
The Destructive One World Order Of The Committee Of 300 must be stopped and the only Major way to stop those animals is by Making Your Own Self-powered LENZELESS RAMATRAFOGEN.
WHEN YOU STARTING TO GENERATE YOUR OWN ELECTRICITY WITH OUTSIDE OF URNING FUEL NOR DEPENDING ON SOLAR, you will be able to do a lot of things this Group of War Mongers hates to see or hear about.
Get your 100% Practically Collapsible Multi-Function Twisted MULTIFILAR Wire Making Machinery  Shipped To You Today!
marathonman
Dude, i don't know if you take medication or you smoked to much weed but you couldn't be any farther from Figuera's device if you tried. but that's ok though.
and damit that pic is big even for my 46 inch screen, i can just imagine a little screen. but that's ok to though.
take a chill pill and reread all the patents then have a brain storm, then come back swinging.
i'm sure you will get it eventually.
and you are right, fuck that committee. i hope they all taste their own blood from the hands of the people they paid to suppress us.
darediamond
Quote from: NRamaswami on March 16, 2016, 04:00:38 AM
Oscar:
I think the Lenz law effect is present in motionless systems in the form of backemf.
Earlier in a solenoid I had a quadfilar primary and a single wire secondary. Both are 4 sq mm. 220 volts and 50 Hz. The quadfilar consumed 220 volts and 15 amps. The secondary produced 300 volts and 10 amps on load. The solenoid was iron core.
I can use a Neon lamp in the primary and use a fast charging and discharging RUN capacitor in series and slow charging and discharging capacitor in parallel along with high ohm resistor in series. Neon lamp is a spark plug and so will increase the frequency. Please provide the ratings for the capacitor in series and capacitors in parallel. I can test the device and find out in practical experiment what is the value of frequency and whether the Lenz effect is there or not.
High frequency is said to heat up the Iron core and so the core will have to be much bigger than at lower Hertz.
Low frequency may not be as efficient as high frequency for the same reasons you provide and Low frequency at 8 to 10 Hz can also resonate with Earths magnetic field and can cause health problems as well. A high voltage line carrying 50 or 60 Hz is said to cause cancers to people living near the line and constructing buildings are prohibited near high voltage power lines for this reason.
Aircraft are said to use 400 Hz but beyond that the wires and the iron core are said to heat up. But I really do not know the answer to this question and I can test and find out high frequency has on input and output. I do practical experiments and then find out and do not accept theoretical statements from any one.
It is possible that high frequency can cause the core to heat up very much and so much larger core may be needed. In so far as the rotary device is concerned if we increase the number of contacts to 100 then for one Revolution per second we have 50 Hz output or for 60 RPM we will have 50 Hz and by increasing the number of contact points or by increasing the Revolutions or by increasing both we can increase the frequency. It is not difficult to do. A spark plug cum resistor in series and a capacitor  in series and in parallel combination can do it much more easily.
Please provide the capacitor values and let me test and tell you the results.  Thank you. I do not accept theoretical statements and test and find out.
There are many lies being fed to  public about Solid Iron and the maximum frequency they can withstand.
You just have go for it Practically and you will even further discover why are they misleading people especially students of Mechanical Engineering and Electronics and Electrical.
60hz rate transformer E I stainless Laminate Can With stand upward of 1khz!
Now let's leave those useless beings in the name of the Committee Of 300 for now.
Let's talk about the main solution or alternative to Solid Iron that can further withstand high voltage.
Your only alternative is to use moulded core which is a mixture of Powdered Iron and Resin and Catalyst and Hardener. You can get Powdered iron and or Magnetite from those less greedy and Humble Chinese and Asians in general at www.aliexpress.com
Just search for Magnetite powder and or Iron Powder. If you will buy more than 1kg, then, simply go to Mabufactures directly or let me say if your country is in Europe or Asia or America, buy directly from nanufacture as shipping fee is lesser from China to 3 mentioned continents.
Let say you are low on budget you can stick a powerful and neodymium magnet to an Iron rod and use that to harvest Magnetite in your area and also at the sea side.
Now how do you make mould for your core?
Assuming you already know how to mix Resin and it 2 other parts in the right proportion, simply get Square  rod or Round Rod of say 10 or 8th diameter by say 20 feet.
Now cut the iron in length to the exact same length of your Primaries and Secondaries or the RamaTrafoGen. For instance, let say after you wind your Primaries using the BEST AND MOST EFFICIENT AND EFFECTIVE WINDING STYLE which is spiral, the length of your primary tube or pipe reached one feet or 30cm, and you secondary 20cm, then you will cut the Iron Rod of either 10mm or 8mm to 2feet (60cm) and 20cm respectively. And you will then make a box which it maximum  length will be between 61cm an 62cm and it width will be determine by the amount of Iron Rods you would like to place inside the Collapsible box. Make sure leave at least 10mm space between the walls of the box and each Iron rod you place in the box. The box walls height if you are gonna use 10mm or 8mm square or round rod should be upto 15mm or 1.5 cm.
Note that you can also use Cement to make your Mould but you will need additional materials which is soft oiled nylon and 4mm or 6mm rods needed to make your Mould well solid.
Also, your Mould wall height will need to increase to at least 25mm or 2.5cm.
Now, you have prepared your Mould box simply apply oil onto the inside of the box all through and also do so onto the rods. Best is to use pure grease.
Now assuming you have finished is he'd oil or greasing the box and rods, Now area get them in the box and space them in accordance with the aforementioned spacing rules.
Afterwards prepare your 2part or 3part Epoxy, stir it rightly and pour the mixture into the Mould and wait for the solution to solidify.
Once it solidifies, then collapse the Mould to get your Main Plastic moulded core Mould.
So now after that, then it is time to start moulding your own Moulded Iron Core Rods Which can withstand high frequency an the megahertz.
darediamond
Quote from: marathonman on March 28, 2016, 11:21:54 PM
Baby!
ignacio
 ignacio
Re: Re-Inventing The Wheel-Part1-Clemente_Figuera-THE INFINITE ENERGY MACHINE
« Reply #3361 on: March 24, 2016, 02:06:57 PM »
Mezclar, escribir textos largos, tergiversar, se usa para que las personas, no puedan prestar atención, al principio expuesto, muchos lo hacen para proteger su trabajo (sus posibles patentes) ¿?
<<Clemente Figuera: reproducir un Generador eléctrico, con las piezas inmóviles.>>
Mix, write long texts, misrepresenting, is used so that people can not pay attention at first exposure, many do to protect your work (possible patents)?
<<Figuera Clemente: Playing an electric generator, with stationary parts.>>
ignacio
« Reply #3371 on: March 25, 2016, 12:17:55 AM »
Si, te dedicas a contestar suposiciones, terminaras desviándote, de tu idea, sigue derecho, y no hagas caso a las menciones.
If you dedicate yourself to answer assumptions, you end up straying from your idea, go straight, and do not listen to the entries.
