ignacio
Solo pruebas rĂ¡pidas, peligroso.
Only rapid tests, dangerous.
NRamaswami
Ignacio..
Avoid dangerous tests. We can always succed with another effort.
While may not be pure Figuera your effort is commendable but avoid taking too high risks.
hanon
Quote from: NRamaswami on April 01, 2016, 03:26:16 PM
Ignacio..
While may not be pure Figuera your effort...
Ramaswami, Your device is the one that each day is farther from Figuera's design. Sparks, high frequency, high voltage,tons of iron required,  , earth connecttions, complex windings, primary and secondary winded one above the other...etc....Nothing of this is ever mentioned in the patents. I do not know what happened to your original design. Your design is more similar to McFarland Cook if so. Your posts are really messy and no clear design can be found there. Sorry for saying this but this is my impression.
Ignacio is using the capacitor to create a second unphased signal, the same thing that the commutator is doing in the 1908 patent. But you have never understood the commutator and I guess you do not know either the function of capacitors.
As fa as I have understood the two electrodes sumerged into water act as a current regulator. It allows to use 220 V AC as input even without any step down transformer. You may adjust  the current into the electromagnets by adjusting the distance between the two electrodes. In simple words is a kind of homemade variable transformer, for quick tests, not for continuous operation.
marathonman
Hanon;
It's more and more like Bozo the Clown tech support and this thread is the Big Top Carnival.
in my opinion there is only a few people on this thread that is actually trying to make the figuera device even remotely like the patent describes. the rest fall into the above category.
hanon
New version on the Patrick Kelly ebook in the section dedicated to Figuera:
http://www.free-energy-info.co.uk/Chapt3.html
I miss some explanation about the opposite movement of the two fields back and forth.
