forest
Quote from: gyvulys666 on April 05, 2016, 12:21:41 PM
forest
how much poles we use in current generators? example permanent magnet generator. how much poles of each magnet we use?
Do you think about one pole only ?
shylo
All that is required is a change, whether it be poles or pole strength , using like poles on opposite sides of a generating coil properly placed , uses the Lenz ,it doesn't fight you .
Lenz will always be there use it instead of trying to fight it.
artv
hanon
Doug,
Your post seems to be quite profound. I have read and reread to try to follow it as far as my knowledge in electrical machinery allows me. Please tell me if I have understood it fine: there are two fields : one required to maintain the load charged and other to keep the machine rotating at its speed to counteract the dragging. Understood fine or not?
marathonman
I'm curious Doug as to what type tech support and the question asked.
All Figuera did was remove the hardest part, work to apply force to make the field move in the form of rotation.
as he said powering the electromagnets takes little as does part G motor.
Good call Shylo.
darediamond
Quote from: NRamaswami on April 02, 2016, 10:17:29 AM
The one person I respect in this thread is Mr. Antijon who spoke the truth that the primaries when given in parallel will have an amplifying effect on the output. I was aware of the same having done many experiments.
The only pieces information that is truthful in the Figuera patent description is that variation of magnetic field strength is sufficient and rotation is not needed and the not so clear image of the electromagnets. Rest of the information is misleading. The output voltage of 550 voltage disclosed in 1902 is also correct.
I do not intend to post or reply here. Simple fact is that the output voltage and amperage must be in excess of input voltage and amperage and it is easily achieved by using thin primaries with high resistance and thick secondaries with lot of turns. The output voltage has to be higher than the input voltage.
Even if I slog it out here due to electromagnetic radiation problems this is not going to be a common device. I intend to work on an Earth battery and no longer going to do this. It is very unfortunate but no one wants to live near high electromagnetic radiation fields. The whole device needs to be put inside the Earth for it to be accepted for common usage.
Thanks to all who responded either positively or negatively.
I think magnetic radiation can be prevented by using aluminium foil tape on the Device somehow or can it not?
