forest
Quote from: a.king21 on April 08, 2016, 07:59:11 AM
My 2 cents worth:
It has occured to me that these effects may only be present in large coils. This is something which Joseph Newman has noticed.
The reason is that coils have a negligible resistance, so a huge coil can be driven with very little current.
Is there any indication anywhere of the SIZE of Figuera's coils? - other than vague newspaper reports.
I'm quite sure there are pictures somewhere...deep in newspapers archives.
darediamond
Quote from: gyvulys666 on April 04, 2016, 01:30:17 PM
darediamond
noone was talking about it is TRUTH OR LIE OR DISINFORMATION. what i wanted to show that electromagnet has 2 poles.  why   should we use only 1 if it has 2? :)
Gyvuly, I love your show of gentleness which commands in-disputable respect.
In the Figuera TrafoGen, unless you mold a collapsible Rectangular Iron core, you can not use the remaining 2 other Poles.
You can Successfully use the other 2 poles if you convert your Paired Straigth Core Lenzless E.Mags to Motor not Motor Gen this time. Which means you will need Neodymium Magnets and set all North Poles on one side and south pole on another. So your pair or Neo.Mag Fitted rotor will have all North facing out on one Rotor and all South Facing out on the other. You can then use the Shaft to drive Whatever you wish.
darediamond
My 2 cents worth:
The Frequency at Which any type of Electromagnet is driven is the UNIVERSAL Determinant of the Amount Of Current it with draw.
This is why is better to use Solid state Switch to pulse a Coil in connection with AC which does not pave way for B.E.F though bef is useful if properly harvested and converted but a bit complex to deal with.
If you make Big High resistance coil and swith at low frequency, it will still consume High Amperage thaan a Small Coil made with thicker Gauge and Switch at High Frequency in the khz.
I am speaking from Practical Experience.
cliff33
Hi gang:
Been doing a lot of thinking about this thing and just wondering why Cf chose such
a high voltage of 550 volts when he could have tested it at 115 volts using only 2 units.
I strongly believe that the higher voltage is the key to the whole thing.
I know he was quite aware of Tesla's high voltage experiments using only pulsed dc.
I'm sure many of you are aware of aether vortexing as taught by "Physics" where he
said to pulse the coils with at least 300 volts using non-reversing dc.
  Others like Moray,Smith,Kapanadze,etc,etc. were all using HV. So all can't be wrong.
For those who ask "where does all this free energy come from", I would say the aether.
Nature always trys to keep things in balance. But sometimes when a group of postively
charged particles accumulate in the atmosphere during a rain storm, they have a strong
tendency to  attract to our negative charged earth. So the lightning does a balancing act.
  So if nature can do it so simply, why can't we?
Not sure but I think it was Tesla that said, these aether particles were so tiny that
an electron would look to be the size of a golf ball.
  Lots of electronic theory on this thread which is fine as long as we don't let it spoil
our main goal (which is very easy to do).
Cliff
NRamaswami
Cliff
High amperage comes only at High voltage.
Only above 300 volts we see a sudden spike in voltage and amperage.
We have to keep the magnetism low in order to get these results. For this we need high input volage and low amperage.
Multiple modules required to reach these results without excessive magnetism and associated high magnetic waves.  Only moderate magnetic field strength in the core meets all these requirements.
Thicker wire can lower the voltage needed. I would suspect CF used either 10 sq mm or 6 sq mm
coils for the secondary wire.
Pulsed dc at high input voltage tends to draw lot of current and will require hugh frequency to reduce the input amps.
