0 Members and 119 Guests are viewing this topic.
darediamond
Quote from: marathonman on April 11, 2016, 12:50:35 PM
Interesting information to know.
The Figuera device is a Motionless Motor Generator with AC output. in convectional Motor Generators, YOU WILL HARDLY GET USEFUL OUTPUT WHEN YOU MOVE TWO NON-OPPOSING FIELD OVER A COIL LET ALONE GETTING AC OUTPUT.
SAME THING IS THE PRINCIPLE OF NATURE. WE HAVE DAY AND NIGTH. YOUR HEARTH IS A PERFECT EXAMPLE OF THIS PROCESS TOO, IT PULSE, SWITCHING ON AND OFF.
SO WHICH THEORY SUPPORTS YOUR NORTH TO NORTH OUTPUT IN YOUR DIAGRAM ABOVE?
The Loads of Components available in this Era were not Available in Figuera's time that was why he used those cumbersome components available in is time.
I know if CF is alive today, he will directly use Solid State Integrated Switch namely Inverter instead of using any ready-made Lenz Oriented and Speed Limited Motors. In every inverter, there are readily Oscilators which have the capabilities that those ready-made motors deliberately made to obey Lenz law be it brushed or brushless do not have. You can even control there frequencies using Potentiometer Position at the appropriate designated  Pin on them.
There are several simple low power usage inverter circuits like the one in the attached picture available now and which can be developed to Power a CORRECTLY (N >> S >> N >> S  etc.) built Figuera TraFoGen.
Figuera had to deal with back E.M.F in is own overunity device because he used DC which emanates from Batteries switched by a mechanical means to Power is Lenzless TraFoGen Primary Coils.
But now in out time, that DC can be easily switched using the always 'Beautiful' ICs you have out there. One such of them is SG3524N. Place Variable resistor on it PIN6 leg and add other simple component as shown in the circuit and viola, you have a Compact Variable Frequency Inverter
One of the Major disadvantage in ready-made Motor-driven mechanical switch is that you, Your Frequency will be  limited by the Maximum Speed Of The Motor which are Always Amperage Hog.
The only solution to this is to build your own Low Amperage High Voltage Pulsed Motor which will require those costly neodymium Magnets.
But why go that slow and costly lane when you HAVE A FAR MORE BETTER OPTION IN THE NAME OF INVERTER??
WHY??
http://www.circuitsgallery.com/2012/09/sg3524-pwm-inverter-circuit2.html
marathonman
You Build it the way you fucking want to build it and i will build it the fucking way I want to build it plain and simple.
as for my last post read the fucking head line "interesting info" that's it, that's all it said butt head.
well build it and quit fucking wining about it. then when youv'e exhausted all your money and the piece of crap doesn't work i'll be laughing my ass off saying "I TOLD YOU SO"
cliff33
Darediamond,
I'll not worry about rectifying the secondary voltage until I can prove to myself  that the thing works.
If can get 200 watts out for only 100 watts in then I know I'm in business and then will try for something better. No point in building an elaborate setup if it doesn't work.
  Hope this answers your question.
darediamond
Quote from: marathonman on April 11, 2016, 10:33:04 PM
Marathon, stop all this your show of immaturity and your DELIBERATE misguidance effort because Tesla, Figuera, Burbosa, Ramaswami etc. can't be wrong winding there Coils CW on one side and CCW on the other side in other to cancel lenz.
I nullified the diagram in your so called "interesting info"  because I have Practically done several research about using ready-made motors to achieve overunity so IN NO WAY ARE YOU QUALIFIED TO TELL ME WHAT WILL WORK OR OTHERWISE with your spirit of deliberate misguidance.
darediamond
Quote from: cliff33 on April 11, 2016, 10:41:53 PM
Darediamond,
No Cliff, stop the twist because my question is Universal. I asked "how will" not "what if' as you made it clear in your reply.
Marathon said there is No need for using High Frequency diodes to tap the output from the Secondary but you refuse to answer how will such action enable anyone to successfully utilized the Sec. output.
If you switch the Secondary at low frequency like 3600rpm or 60hz, too much amperage will be drained from your battery or Super Cap Bank so high frequency is the answer and what household devices operates at upward of 500hz anywhere in the world? Can you please mention one?
Figuera is not alive today to teach us how he REALLY set-up his devise to achieve overunity as presented in his Patent but the Primary principle he applied was also used by Tesla and in later days Burbosa and Mr Ramaswami of India. And that Primary Principle lies in Winding one Primary in Clockwise direction and Winding the other in Anti-clockwise and then linking them in PARALLEL not serial.
So could you please again answer my question rigthly
So please
So if you follow that foundation you will sure achieved what Figuera, Tesla and co achieved which is the Negation of Lenz the Limitation to Overunity achievement.
But wait, why take Paracetamol for another Man's headache? Are Marathon in disguise??
