darediamond
For a certainty, you can turn a Transformer into a Generator if:
1. Lenz is 100% Practically Negated like Thanes Heins did with his Transformer.
2. High Frequency is used to Run the Primary.
3. The Secondary Wire is Substantially THICK
Lenz negation, High Frequency application and Thick Gauge usage is a M U S T!!
Why?
When lenz is negated, the Secondary will NOT RELY ON THE INPUT OF THE PRIMARY TO POWER A LOAD. This means that when you load down the secondary, it will not draw more power from the Primary but instead, it will draw the needed Electrons from the AIR at the correct operating Frequency as the are is constantly charged by Forces that holds the Planet Earth Upon Nothing in the Space. Thanes Heins did this and other people who replicated his work achieved this effect too.Y
When you wound a coil and switch or Pulse it at 60hz, it will generate weak magnetic strength and draw High Current. But if you increase the Frequency to 600hz, the magnetic strength will enormously increase while it Amp draw will reduce.
But the Point here is that once you wound your whole Transformer to Negate Lenz effect, what will determine the amount of Overunity Power it will be able to generate is How thick your Secondary wire is and the Speed(Frequency) of Rotation of the Flux of the Primary over the Secondary.
The thikcer your secondary wire is, the Lesser it resistance. The lesser it Resistance, the Higher the Speed or Frequency at which the secondary winding can be driven. The Higher the Speed the secondary can be driven at, the Higher the Amount Of Bait Electrons that will be available to attract the Atmospheric electrons into the Lenzless Pulsing Secondary.
The only limitation is the amount of Maximum Frequency the Core of the TrafoGen can withstand. So it is best to use Moulded Core.
Remember that the Principle of Overunity lies in using 1 to generate 100 or more. So you need to drive your Primary at High Frequency to reduce amp draw.
Your Primary Wire Gauge Ratio could be 1:4 i.e Primary 1mm diameter Coated Copper Wire while Secondary 4mm diameter Coated Copper Wire or better 1: 8  where the 8mm could be further divided into 1mm in eigth places and converterd to Bifilar Wire (the best effect).
You Must make sure the Resistance in the Primary is very much Higher than the Resistance in the Secondary.
Spiral Winding gives the Best Result. So wind your Primary and Secondary in like manner.
Do not put any winding under the Two opposing Primaries Spiral Windings.
You Must Wind your Opposing Primaries in CC<> CCW and if you wanna go express then CC <> CCW <> CC <> CCW <> CC etc. is the  only correct configuration. <> denotes the intermediate Secondaries. When you  have multiple Secondaries, it is best to use Fast Switchicing Diodes to Rectify there Outputs and separately Link them to individual High Capacitance DC Capacitors and further use High Amp Rating Diodes to ink the Capacitors in S  E  R  I  E  S.
When you use Capacitors and Diodes with Field Coils this way, the Voltage and Current are Multiplied together unlike in battery case.
Also, the earlier referred to attracted Atmospheric Electrons lured by the bait electrons on the Secondaries get easily locked and converted to Hot Electricity. So this help TO EXTREMELY RAMP UP THE OVERUNITY EFFECT MORE THAN IT WOULD HAVE BEEN IF THE SECONDARY COILS ARE JUST CONNECTED IN SERIES STRAIGHT AWAY WITHOUT THE INTERMEDIATE HIGH FREQUENCY DIODES AND HIGH CAPACITANCE DC CAPACITORS.
Other names to High frequency diodes are fast recovery diodes, fast switching diodes etc. You can get them cheaply from chineese at www.aiexpress.com
The overunity setting of this device necessitate AC usage as kickstarter. Thus a Variable Frequency Pure Sine Wave Inverter must be used.
I have in my earlier comment post a PWM inveter circuit and have stated how it can be easily made to be adjustable frequency. So search for that post. But you can do better. I would recommend buying Moulded Core on same aliexpress to make your own Center tapped inverter Transformer so as to easily drive your primaries at high frequency and take records of the best frequency.
Lest I forget, When you wind a Transformer and drive it at say 60hz and it Secondary output is maximum of 60W while it Primary is consuming 60W (turns Ratio), AT 600HZ, THE PRIMARY OF THE SAME TRANSFORMER WILL BE CONSUMING LESSER WATTAGE WHILE IT SECONDARY OUTPUT WILL BE AT MINIMUM OF 60W STILL.
BUT BECAUSE OF LENZ WHICH IS MADE TO BE BY THE WINDING STYLE OF MOST TRANSFORMER OUT THERE, WHEN SUCH TRANSFORMERS ARE LOADED, then the primary will start to draw more current and Overunity achievement get badly marred.
The Secret here is that, A Transformer is Readily a Generator Provided You Wind it to Negate Lenz and drive it Primary at High Frequency.
hanon
Quote from: darediamond on April 27, 2016, 07:10:38 PM
Totally contrary to the teaching of Figuera. Figuera used mechanical switching, therefore he could have just used low frequency excitation. He did not used spark gaps nor electronic circuits, so he could not get high frequency. Please read the patent and study it. Figuera used around 100 V and 1A.
You see. It is not me the one who is suggesting using HF. HF is asociated to high voltage and therefore microwaves. Take care. This is totally contrary to the low frequency generator of Figuera. Which is the maximum frequency that you may get with a mechanical switching? 50 Hz, maybe 100 Hz? This device is as the one from Hubbard, Hendershoot generator, all powered at low frequencies. Please do not propose systems far away from the patent design.
darediamond
Quote from: hanon on April 28, 2016, 04:11:43 PM
Hanon, when will you change for better? When?
In one of my comments where I deliberately and beneficially nullified Marathon's mechanical switching image, I stated the reasons why I did and why anyone who wants GENUINE and Long-lasting switch should not use Mechanical Switch which I have practically tested.
Below is the said comment again:
"The Figuera device is a Motionless Motor Generator with AC output. in convectional Motor Generators, YOU WILL HARDLY GET USEFUL OUTPUT WHEN YOU MOVE TWO NON-OPPOSING FIELD OVER A COIL LET ALONE GETTING AC OUTPUT.
SAME THING IS THE PRINCIPLE OF NATURE. WE HAVE DAY AND NIGTH. YOUR HEARTH IS A PERFECT EXAMPLE OF THIS PROCESS TOO, IT PULSE, SWITCHING ON AND OFF.
SO WHICH THEORY SUPPORTS YOUR NORTH TO NORTH OUTPUT IN YOUR DIAGRAM ABOVE?
The Loads of Components available in this Era were not Available in Figuera's time that was why he used those cumbersome components available in is time.
I know if CF is alive today, he will directly use Solid State Integrated Switch namely Inverter instead of using any ready-made Lenz Oriented and Speed Limited Motors. In every inverter, there are readily Oscilators which have the capabilities that those ready-made motors deliberately made to obey Lenz law be it brushed or brushless do not have. You can even control there frequencies using Potentiometer Position at the appropriate designated  Pin on them.
There are several simple low power usage inverter circuits like the one in the attached picture available now and which can be developed to Power a CORRECTLY (N >> S >> N >> S  etc.) built Figuera TraFoGen.
Figuera had to deal with back E.M.F in is own overunity device because he used DC which emanates from Batteries switched by a mechanical means to Power is Lenzless TraFoGen Primary Coils.
But now in out time, that DC can be easily switched using the always 'Beautiful' ICs you have out there. One such of them is SG3524N. Place Variable resistor on it PIN6 leg and add other simple component as shown in the circuit and viola, you have a Compact Variable Frequency Inverter
One of the Major disadvantage in ready-made Motor-driven mechanical switch is that your Frequency will be  limited by the Maximum Speed Of The Motor which are Always Amperage Hog.
The only solution to this is to build your own Low Amperage High Voltage Pulsed Motor which will require those costly neodymium Magnets.
But why go that slow and costly lane when you HAVE A FAR MORE BETTER OPTION IN THE NAME OF INVERTER??
WHY??
http://www.circuitsgallery.com/2012/09/sg3524-pwm-inverter-circuit2.html"
So do you get the drift now Mr. Hanon?
Figuera's time was 1800 ours is 2000 what a stark difference. Must we now still stay hooked to keep the organic fish? No
High Frequency must be used to keep down massively the Primary input Wattage.
Now that advance and easier to integrate chips are available, you can separately switch a coil at whatever level of voltage. Even you can switch 12V dc or ac at 500khz if you wish. But that you can never do such using a Mechanical Switch like Copper Commutator and Carbon Brush.
So please STOP telling me not to encourage people to go for BETTER and SIMPLER Options which are not available  in Figuera's era.
You must use High frequency so as to enable you to loop the system easily powering the Primary with a Battery and low Wattage Inverter.
Discharging batteries at high amperage will get them weak quickly. So you just need to make sure you are not discharging your batteries above the Maximum rated amperage. And the only way to ensure this is to drive your Primary at High Frequency people.
Like I said yesterday, if at 60hz your Primary is consuming 200W, if you increase the switching speed to say 600hz or more, the input wattage will drop to 20W or less and the Ouput wattage will increase. And if you are able to achieve that, then you can just use a 100W Variable frequency Pure Sine wave Inverter to Power your Primaries and do the Self-charging thing on the other side of the Motionless MoGen and Further tap Power to Power your devices.
You do not have keep to Figuera style to succeed. All is need is common sense. You need to know what to Add and What to Subtract simple.
marathonman
It's amazing, people that DON'T even Know what PART G is are suddenly an EXPERT on Figuera with no working device giving out advice on how to build a free energy device.
NOW THAT'S PRECIOUS.
Hanon can i interest you in two SHAM WOW'S and some rubber spoons for the invaluable Tech support you just received.
you should be thrilled.
The heart pulses in a vortech motion. meaning it twist's as it contracts, if you want to sound like you know anything at least research it first.
Doug1
Once the machine is operating where does the power come from to operate it? If it comes from the machine itself why would i care how much it uses to operate?
  The short bus runeth over?
