marathonman
Oh stop being a baby Hanon, i'm not attacking you just you keep posting the same stuff over and over and do nothing with the info at hand. i want you to raise up to the next level so please don't pout and run away without taking good information and run with it.
Very good Mr cliff i see some advancement and someone is finally using their brain. good post !
after you finish your design, get it working,  then you can work on building the real part G to make it self running.(Magnetic resistance)
an easy way to cheat and avoid all the calculations is download this calc tool. i use it very much in my studies and research. http://www.electronics2000.co.uk/calc/
it is cheaper to use magnetic fields to curtail currant flow then resistors. you must of spent a small fortune on high power resistors.
good to see active participation and not sit on the knowledge.  i'm sure you remembered to make your timing circuit make before break (timing overlap) so no bemf occurs in your primaries. (simple cap will do that)  just remember that each primary must handle half of the secondary output. 14.8 lbs force shifted side to side = 1 kilowatt so each primary must put out 7.4 lbs force shifted side to side. but can be divided even further depending on what force you are comfortable in dealing with. just remember these are opposing electromagnets and will fly apart and tear things apart when they do so please be careful and secure them properly.
Happy building Mr. cliff
hanon
Quote from: cliff33 on July 07, 2016, 03:42:48 PM
For those who really want to replicate this thing,just study C.F's comments.
He says " Because of the splitting of the primary into two parts, Lenz's law
has been abolished for this design, allowing a spectacular performance where
the current drawn from the secondary winding has no effect on the current flowing
in the two halves of the primary winding. There is also no back -EMF as current
flows continuously in both halves of the primary winding."
Why do you quote Figuera "..." with sentences that he never wrote down? He never told that. Where is that written? Where?
Guys, you see the problem with interpretation. People put words in Figuera mouth because of their own interpretations. Please keep separated Figuera's words from your words. I have read tens of times Figuera's patents and he never used the words: north, south, Lenz, back emf, so your post is not a quote from Figuera.
That's why I kept the original spanish text into the patent translation, so that if anyone does not trust the current translations he can re-translate them from the original text. For me Figuera's words are sacred, and must be kept intact forever.
I left because I have no new info to present and share. I know that I post again and again the same, hoping to convert newcomers, but as I said I am fed up with the agressivity in this forum.
The sketch I post below was done by marathonman after my suggestion that I think that Figuera used to resistors arrays instead of just one to have two exactly simetrical and opposite signals, the trick is to mantain always the same resintance in the two resistors arrays to guarantee a constant sum of the two current intensities. Cliff, this is for you. I have also another sketch of that by myself but it is handmade and it is not so pretty as this one.
Bye bye, (I hope not to go back to defend Figuera)
cliff33
Hanon:
Sorry for the misquote. I got this info from chap.3 of PJK's book. So I modified my post.
I've always had great respect for Patrick and all of his research.
Keep up the good job of translating.
Marathon:
  Thanks for the comments, but no I will not be using any resistors or coils to vary magnetic field.
The "G" device also is not on my agenda.
I'll just be using two power mosfets for my system. Good mosfets don't consume any power, they just vary the amperage.
We all have our different ways which is good.
DreamThinkBuild
Hi Hanon,
I appreciate all your work in translating the patents. From your site I offer a mechanical emulation of the field movement you portray, this is made with cylinder magnets, not ring magnets.
allcanadian
@marathonman
Quoteit is cheaper to use magnetic fields to curtail currant flow then resistors. you must of spent a small fortune on high power resistors.
I use arc welder copper clad carbon gouging rods as power resistors which are inexpensive. I just slit the copper cladding and peel it off or some copper on the ends can stay on if you want to solder then into a circuit. I have used them as dummy loads for years and they are pretty much bulletproof. They also work well as current shunt resistors and I have had no issues to date.
AC
