0 Members and 39 Guests are viewing this topic.
marathonman
Your ignorance simply amasses me. there's a wealth of knowledge on the table yet you choose to ignore it and do what do best, run your mouth.
i'm really impressed.
and you wonder why you don't have a working device. so now your on two forums spreading your stupidity, how quaint .
you remind me of Einstein, he to was border line retarded and amounted to nothing,  spouting nonsense.
please do this thread a favor and move on to another thread if all you come with is negativity.
wistiti
Quote from: marathonman on July 24, 2016, 02:07:34 AM
Sorry, no magnetic resistive devices on the market. you will have to build it.
Wow! really.
can be made for one light bulb or 1 million light bulbs. sky is the limit.
no need to be sorry, except for question #2.
read patent and repeat.
Ok thanks!
So for the G part do you recomand me to follow the pjkbook?
Ciao!
marathonman
 tests are being done now to determine if part G can be put on a laminated straight block core. this will allow a more simple implementation of part G. especially if transistors are used on the high side in make-before-break set up.
for now i would say "YES'  but be fore warned part G is a bitch to wind in the toroid form because of the thicker wire used.
when Figuera was describing part G's commutator bars he was actually describing the winding's them selves which were "thick" wound over the core.
another good piece of info is part G can be laminated typical toroid but remember the toroid va rating must be more then supplied power to  each of the primaries.
so let's say you had as an example; 500 watts going to your set N (high) and 250 watts to set S (low) then that's 750 watts. i would have part G's core rated at no less than 1250 watts.
it doesn't matter how many watts you feed the primaries because the inductive kick back from the receding electromagets replace the power used every half rotation of part G. as long as that is followed it will be self running.
MM.
darediamond
Quote from: marathonman on July 24, 2016, 05:33:23 PM
How smart are you in covering your lousy tracks?
You ain't smart at it all.
No I am not spreading negative thought about you. Those words about you are not mine. Are they? No they are not. And till date, youbhave not changed for better.
It took the pruning effort of many members on here before you stop using vulgar words and now left with oudated "evangelical lies".
Oh, can you show us your own personal working device?
marathonman
I don't have to cover my tracks, people make mistakes. it is all about learning from them in which i did and then some. my knowledge of the Figuera device surpasses most everyone on this forum except Doug. why ? because of my desire to succeed and learn.
i freely share what i have learned and if that's a crime then i am guilty as charged.
i would suggest you quite living in the past and get back to your research.
i really doubt your on this forum to learn though, your actions say otherwise. this is probably why no one listens to you because of your ill intentions.
i almost feel sorry for you, NOT!
good day Mr. darediamond
