0 Members and 36 Guests are viewing this topic.
marathonman
Quote; "If the Ramaswami transformer is an improved design of the Figuera generator, as you stated,  go and create a new thread about it. Please. Do it and leave the rest of us to replicate the original design".
I AGREE WHOLEHEARTEDLY !
take your TRANSFORMER not (GENERATOR) to another thread. mater of fact i thought you did that already. what happened nobody cared for your bull shit lies so you came squirming back to totally screw this thread up. your dream of your device being an improved  design is a complete fallacy created in your own mind that NO ONE CARES TO PARTICIPATE IN. yet your ignorant to see this fact that is right in front of your FACE.
marathonman
wistiti ;
your primaries should be the lowest ohm's possible. part G controls the currant allowed through the primaries not the other way around.
this calc tool is easier to use, no mm squared to deal with.
http://www.calctool.org/CALC/phys/electromagnetism/solenoid
and a vary ignorant comment about myself having more than account. well all i can do is to tell the accuser to contact the owner or site maintainer  and check my web address assigned to my account and check for other registered accounts. thus you will see you are blowing smoke up every ones ass and wasting every ones time polluting this website with your bull shit comments and suggestions .
marathonman
Quote from: Cadman on August 05, 2016, 02:19:50 PM
OK Mr. Ramaswami.
I think you are missing the point in the video but I have no desire to argue with you or anyone else here. Life is too short.
To anyone who watches that video and only sees a moving core, please look more carefully at the setup and see everything else that is there. Is the flux balanced from one end to the other? You should be able to imagine how the flux will be arranged in the two setups. The strength of the magnets does not change. Their polarity is not alternating back and forth. The method of actuation is the same. The coil is the same.
So what must be the cause of one induced emf being higher than the other? The video relates to the Figuera generator. How?
CM
Cadman;  you are wasting your time talking to these simple mined single sided individuals that take things at face value. (visually)
just like the table top demo William Hooper did,  he moved the magnets in unison exactly as the video did. this causes a double intensity E field to form. the goof can't see what is really happening because of his extremely narrow mind and inability to see outside the box.
this is the Figuera device all day long. they moved the magnets, Figuera moved the magnetic field, plain and simple. ( except to a few)
and in order to do this Figuera figured out that he could get completely separate feeds from one DC feed by opposing magnetic fields in part G. this device can be built by anyone at home to prove it's validity.
take some bare wire and wrap a iron or laminated core that has been coated with (your choice)) an insulator. put about 20 winds of thick or rectangle wire around the core (not touching) then secure. take two twelve volt car bulbs and attach the two ends of the core to each of the positive side of the bulbs. take the remaining bulb wire and connect to the negative side of the battery. now take the positive side, with attached wire and touch the core winding's in the middle.
what do you think will happen, both bulb intensities are the same. now touch at either end of the coil and see what happens, one bulb will be bright and the other dim. do the other end and see the bulb that was bright is now dim and the dim bulb is now bright.  if this is done in rapid succession this will mimic the actions of the figuera device completely.
Congratulations you just built your fist Figuera part G consisting of a splitter of currants and a magnetic resistor.
MM
hanon
Quote from: marathonman on August 06, 2016, 06:22:56 PM
take some bare wire and wrap a iron or laminated core that has been coated with (your choice)) an insulator. put about 20 winds of thick or rectangle wire around the core (not touching) then secure. take two twelve volt car bulbs and attach the two ends of the core to each of the positive side of the bulb. take the remaining bulb wire and connect to the negative side of the battery. now take the positive side, with attached wire and touch the core winding's in the middle.
MM
Marathonman, Thanks for providing this simple test. I will do it. Just one question. You wrote to use an iron or laminated core. Does that core need to be a toroidal core or just a straight core may be used in this test?
While I am still waiting for the quote that Ramaswami told that Figuera wrote, I link below another great sentence from Ramaswami:
Quote from: NRamaswami on August 05, 2016, 01:05:11 AM
The Part G is a current interrupter which makes the current supplied interrupted current or pulsed DC input.
Confusion: This is the aim of some guests of this thread. I have no doubts now.
marathonman
straight core my friend, just a simple little test.
yes we know hanon, it like, he's a rock, trying to tell another rock about sponges. DUH ! the irony.
it's actually the fluctuating DC that makes it all work ln part G . pulsed dc or ac will not work , END OF STORY.
