0 Members and 40 Guests are viewing this topic.
Cadman
MM,
This is the second time you have revealed this little test. I bet people will start paying more attention to what you've said now.
CM
darediamond
Quote from: hanon on August 05, 2016, 12:18:32 PM
The problem with Ramaswami and Darediamond is because they are just using pulsed DC or AC to feed the generator. They did not have ever used the two signals created in the commutator properly built. Therefore they just have results with North-South polarity. With North-North they have null results with pulsed DC or AC as expected because they are not moving the fields. North-North requires the use the comutator described in the 1908 patent. Period.
I do not know how Ramaswami says that North-North, or South-South, does not work if he have never built the commutator as the patent describes. And he just repeat and repeat that the commutator is just to pulse the current. This is totally false. Also are false some statements done by Darediamond some days before telling that the commutator may be sustituted by a sine wave inverter. False. Please study the commutator.
What is it is to be studied about Part G which you are wrongfully promoting? Are you saying in this modern times, there is no 100% better efficiency to that Part G of a thing?.
Shows us your working model to support Part G being better than Alternate Current which do switch Polarity Without going down to Zero frequency.
Figuera Generator is Simple to build that why you and your cohorts are bent on misinformation deliberately.
When you Fluctuate DC via an Iron core be it moulded or otherwise what do you get as output current? Is it not Alternate Current?
How do you make the Primaries consume low current if you utilized low frequency like 60hz? And how do you generate extremely Powerful Flux if you do not utilise Twisted Serially Connected Multi strand Wire?
You want to Move the Magnetic Field by Bucking the field, WHAT SENSE IS IN THAT WHEN IT IS WIDELY KNOWN THAT:
1: South Pole Flux always flows to North??
2: Alternate Current will only allow for constant continuous Flux Pole Switching on each Primaries because AV do not have POLARITY like Pulsing DC nor DC?
The Figuera Gen utilises AC which the Part G is producing outrightly.
And the Oscillation or High and Low,  Low and High is caused by Alternate Current Application because at one cycle Primary On The Left will have South and North and Simultaneously, Primary On the Rigth.will have South and North Vice-Versa  and this will create Addition of Power at the center Where the secondary is not repulsion (Bucking Mode).
The interpretation of this is Motor Generator without applying Permanent Magnet as it is widely applied in AC Generators.
Now to get Pure Lenzless output, Buck the Secondary by Splitting it into 2 go the way of Chris Sykes A.K.A EMJunkie to connect them together.
Download is guide on Partnered Output Coils here http://www.hyiq.org/Downloads/Guidelines%20to%20Bucking%20Coils.pdf to understand deeper why the secondary must be bucked.
Do not let anyone think for you; Think it out by yourself so to get librated.
darediamond
To create addition of Flux in Figuera Gen, wind your primary on the.rigth and left in same direction and connect there leads in Parallel.
But to get pure lenzless output,  split your secondary into 2 and wind each part in Opposite directions and connect there leads in parallel.
To use low amount of Wire to generate HighbAmount Of Flux, divide your length of wire equallybinto multiple part and twist it together and use that to make your Primaries.
To use a single setup to generated high amount of Lenzless Output Wattage and keep heat down,You must use High Frequency, Moulded Core or large amount of Solid Iron Rods stucked into big plastic pipes.
wistiti
Quote from: marathonman on August 06, 2016, 06:22:56 PM
Cadman;  you are wasting your time talking to these simple mined single sided individuals that take things at face value. (visually)
just like the table top demo William Hooper did,  he moved the magnets in unison exactly as the video did. this causes a double intensity E field to form. the goof can't see what is really happening because of his extremely narrow mind and inability to see outside the box.
this is the Figuera device all day long. they moved the magnets, Figuera moved the magnetic field, plain and simple. ( except to a few)
and in order to do this Figuera figured out that he could get completely separate feeds from one DC feed by opposing magnetic fields in part G. this device can be built by anyone at home to prove it's validity.
take some bare wire and wrap a iron or laminated core that has been coated with (your choice)) an insulator. put about 20 winds of thick or rectangle wire around the core (not touching) then secure. take two twelve volt car bulbs and attach the two ends of the core to each of the positive side of the bulbs. take the remaining bulb wire and connect to the negative side of the battery. now take the positive side, with attached wire and touch the core winding's in the middle.
what do you think will happen, both bulb intensities are the same. now touch at either end of the coil and see what happens, one bulb will be bright and the other dim. do the other end and see the bulb that was bright is now dim and the dim bulb is now bright.  if this is done in rapid succession this will mimic the actions of the figuera device completely.
Congratulations you just built your fist Figuera part G consisting of a splitter of currants and a magnetic resistor.
MM
Hi MM.
I have test it on a ferite rod but can  not see a particular difference in the brightness of the bulb... :-\
I have put insulating tape between the ferrite ans the bare wire. When i touch with the + of the batt on the left side or the right. The intensity of both bulb are the same...
Any advice are welcome!
