darediamond
The Part G like I have been saying is a mechanical Inverter and unless you do what I did last year over a test Pulsed Motor I built in 2015 , you will never have a smoothly running Part G.
I shared the video with Ramaswami so get it from him to learn.
However do we still really need to use that cumbersome Part G to convert D.C to A.C?
Practically NO is the answer because Motionless or non-mechanical D.C to A.C Inverter can now be easily bought or even built.
I am not against the Part-G per say. what I am against is making it appear as the only best option and of course telling  lies about the correct polarity of Figuera Gen which Marathonman the Kite is doing actively.
Infact I know 2 other mechanical means of converting  DC to AC.
Ramaswami,  Direct Current and Pulsing DC do not have frequency. But Pulsing DC can only be achieved using half bridge rectifier which means using one diode on one of the AC leads from an A.C source.
You can only make a D.C and Pulsing DC have frequency by passing them via a Transistor or MOSFET or mechanical Commutator.
So if you use thin gauge to wind the Primaries of your C.F MoGen, then you must use High Frequency and High Voltage.to quench there thirst for current. Increasing Voltage is not enough if you wanna really achieve overunity with.ease.
Also, the higher the frequency, the higher the Output Wattage ( V *I)
You do not  need high current to generate conc Flux. All you need is Serially Connected Multi strand Wire and High Frequency and optionally High Voltage.
But you must remember that your core must be Big enough to withstand the high frequency you will be applying or else, there will be Heat and Saturation. The Higher The Frequency, the Stronger The Flux Becomes. The Higher the speed at which you switch or Move the Flux, the higher the output Wattage Becomes.
You need not to saturate the Core to achieve over unity all you need is proper winding and connection style of the underlying, overlapping and central Secondary Windings as you can now have 3 split Secondaries for 2 opposing Primaries. The Secondaries must be in Opposing Mode I.e: NN or SS while the Primaries must be in Addition Mode I.e NS NS.
You must Buck the Secondaries.
Again it is best to use Moulded core as the unit will be smaller and Still Generate high output because it can withstand High Frequency.
Marathonman now over to you.....
hanon
Quote from: darediamond on August 11, 2016, 06:06:16 AM
Be Wise.
Part G is a DC to AC converter in mechanical way.
Another one who does not understand the commutator Part G. Please read the patent again. Or maybe for the first time.
AC = 1 signal
Commutator = 2 signals, one to feed each set of electromagnets.
Wind your Primaries in Attraction Mode  but your secondaries in Repulsion Mode and Utilise AC to activate the Motionless MOGEN youbhave just created.
Supoose two primaries and two secondaries coils in the middle of the primaries. If the primaries are in attraction mode the only field transversing both secondaries is:
N ---------------> S. As per Lenz, the induced field of each secondary will be <-------- in one secondary and  <-------- in the other secondary. Both opposing to the primary field. How the hell are you going to buck both secondaries? Impossible. No way
If the primaries are in repulsion their fields will be N -------> <--------- N  . In this case one secondary will oppose to its closer primary field: <--------  and the other secondary will oppose to the primary field of the other primary coil:  -------->. There you have two bucking secondary coils. Perfect bucking output coils. In this case you may use pulsed DC. You just need to collide two fields in the center point, right in the point between both secondaries coild, no need for movement of the fields in this design based in flux linking.
Summary :
Attraction  N ------------------------>  S
Repulsion  N ----------> <-----------  S
See this sketch of Daniel Dingel device. The second sketch is drawn by me
Doug1
 Diamond no inverter needed no work is mo beter.
https://www.youtube.com/watch?v=xT20j9lJYK8
Shhh it's conspiracy dont tell diamond there is only one person on the internet.
gmolina
Quote from: hanon on August 11, 2016, 06:42:40 PM
AC = 1 signal
Hi, Hanon you can get two opposing poles with 2 signal of AC out of phase 90º.
See attach.
GM
hanon
Gmolina,
Figuera used two signals unphased 180°, not 90°. The patent states clearly that when one was at maximum the other was at minimum and viceversa. That why he patented his commutator and included it in the patent claims. In other cases he has said that AC was valid. If that were the case some very smart guys as Darediamond will had used AC from other known method in that time, as a common geneerator, and they had bypassed the patent protection. That is not the case.
I wonder if people really had read in deepth the patents. At least the patents and understand them. Later you may test all possibilities with the polarity NN , SS,  NS. But for clear reason I think some users dont have the problem of not understanding the commutator. They are just creating confusion and hijacking this thread for some reason.... Patents are our bible. The rest are interpretations
