0 Members and 36 Guests are viewing this topic.
Cadman
Quote from: NRamaswami on August 13, 2016, 12:14:14 AM
Mr. Cadman..You have indicated that the Ramaswami device configuration works but is COP<1. ...
No, sorry, I have never ever built a "Ramaswami" device. I built a N-S pole, 2 inducer, 1 induced, PWM DC sine wave setup that was COP<1, and that was before you made your first post in this thread.
I have learned a lot since then and I have a clear build concept to follow now.
CM
darediamond
"When you negate Lenz in a Coil or transformer, to achieve overunity, just increase the magnetic flux and frequency and the Zero Point Energy Field will flow freely into your Coil to multiply your Output.
The use of Bifilar will not give much Magnetic Flux like using serially connected 20 strands and above.
The rate at which you drive the Concentrated Flux will determine the amount of Radiant Energy the Secondary will be able to Pump out for you. Also, the Gauge number of your secondary matters.
Though it can be used that way, Partnered output coils are actually overunity Generator in Disguise so treat them as such by using thin Gauge like 0.31mm wire for your Primary which must be wound with Multifilar wire of that stated gauge. Now drive the Powerful output FLUX of that Primary with HIGH FREQUENCY. Wind your secondaries with Thick gauge like AWG15 or AWG 8 etc. to get concentrated Electrons from the environment and thus keep down the driving current from the power supply.
Note: the amount of Flux your primary is outputting and the gauge of of your secondaries will determine the amount of usable power that will be available in the Primary. Your Core Must be Moulded Core be it industrially manufactured or homemade (recommended). You need High Frelquency, Super Strong Flux from the primary to fully turn bucking output coils into Overunity Generator. Your Core must be Big enough to withstand the Flux your Splitted Pralled Primaries will be Producing.
*Do not limit yourself to 20 strands as I mentioned earlier, you can go as high as 200 strands.
0.31mm coated copper wire is 5grams per 24foot 5inches. So 200 strands of that twisted together will give 1kg which you can even divide into two to make it 400 strands and connect each strand in series to the next one provide you can patiently do so.
Hint: To remove coating of enamel on each leads at a time, briefly subjet them all to burning Gas.
AWG#30 is 32ohms per 100g and 1.5ohms per 5g. Generally, the higher the ohmic value of a coil, the higher the needed voltage to drive to generate it Maximum Flux.
Learn to make Litz wire making machine. You need it. There are 2 versions now which can be made using wood like I did.
To get high magnetic flux high current is not needed so using thinner gauge is better as that will require high voltage which will also aid the flow of z.p.e over the secondaries and reduce input current further.
You can power your bucking coil using AC to avoid back emf of DC. Just make an High Frequency Pure Sine Wave Inverter which Have Moulded Core Center tapped High Voltage Transformer and supply the output of the Transformer from the inverter to your Bucking Coil Overunity TrafoGen Primary and use Diodes to rectify the higher output with High frequency diodes like HER508 and Invert it again to Generate AC and from there, make the set up self charging by converting the AC from the second inverter to DC using an AC to DC converter and link that to your Battery or better High Farad Serially Connected Super Capacitor Bank(The BEST OPTION)
Good luck."
NRamaswami
Jegz
Thanks for your kind words.
I can confirm that if we increase the number of wires in the multifilar coil inductive impedance increases enormously and very low current is drawn but high magnetic field is achieved in primary core. We have done this even before I started posting here and has disclosed it in one of my first posts.
I will not post here until I can post a video.
Thanks again
Doug1
darediamond
Quote from: NRamaswami on August 13, 2016, 05:39:18 PM
Jegz
Thanks againr
Sir,
You do notnhave to increase turns of wire in Multifilar. All you need do is to increase turns without using additional wire.
How do you do this?
Simply divide into further sections the same Multifilar wire you made your primaries with and connect the new leads in series still.
Each leads will store the same amount of energy and when in series, the.power will add up and that makes it Super Powerful.
