0 Members and 27 Guests are viewing this topic.
Doug1
Im sure you have a couple magnets laying around.Take one of them and place it close to everything in your environment and find something that will push the magnet away.
Im not trying to make you look foolish, your the one who insists on the down and dirty with hands on proof.
Doug1
 Matu
He should at least get his hands a little dirty. So there you have it.For all you belly aching you could have just used a couple a magnets to figure out there is third field created between the two active fields in motion. The two active fields are kept separate from the center field and only the force is used to move the central field. the only difference from a rotating generator to motionless and the difference between a generator and transformer. Transformers use one field which is consumed in the load through the secondary. All other improvements aside even a child could it.
  Generators have to be flashed leaving a week field locked in the cores once it starts to rotate the field breaks into two one moving and one not. Figurea or Baforn state there is no residual magnetism when not operating. When do two magnets cancel each other out? NN or SN.
Doug1
Oh you dont see the permanent magnet dropping off to zero flux on ether side just the movement under the glass which is limited in distance.If he moved it far enough the effect would be lost.
