0 Members and 70 Guests are viewing this topic.
shadow119g
Doug1?
Since you us sixty hertz for your DC device, I am assuming that you
you convert the DC to AC for usable electricity.
If that is what happens...how does it happen?
Thank you,
Shadow
Doug1
Shadow is that a trick question? Did you phrase it correctly? Clarify. It's a generator not a transformer.
From where shall come the energy/power gain ?
Thinking about a magnetic circuit,included a permanent magnet,we will get a magnetic force amplification !
This magnetic force has to become converted to electric force !
But we would only get for 1x time this amplification,because this we have to use the known "Barkhausen effect"(the magnetic force polarisation change) by pulsation,based by using the wave/frequency/pulse generator !
Flip and flop principle,commutation.
shadow119g
It is a generator, but I don't see that in the process where it
generates AC electricity. It seams to me the output would
be pulsed DC where the voltage starts at or near zero then
increasing to a maximum then decreasing back to the near
zero state.
AC as I know it starts at zero then increases
above zero then decreases below zero the same amount
it goes above zero returning to zero for the completion
of one wave.
Thanks,
Shadow
Controlling the generation of magnetic force :
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=4757419A&KC=A&FT=D&ND=3&date=19880712&DB=EPODOC&locale=en_EP#
The present invention provides an apparatus for generating with a relatively small electricity a pulse line of magnetic force, wherein a diode is connected to a switching device, in other words, a controlled rectifier such as thyristor, in reverse parallel, or to a charge and discharge capacitance in parallel to cancel the negative voltage stored in the capacitance so that the peak charge current is suppressed to 1/3, and also so that the quantity of electricity used to charge the capacitance is reduced to 1/2.5, in comparison with those of conventional apparatus.
Compare Figure 2 with Figure 4
https://worldwide.espacenet.com/publicationDetails/mosaics?CC=US&NR=4757419A&KC=A&FT=D&ND=3&date=19880712&DB=EPODOC&locale=en_EP#
    More particularly, the present invention relates to an apparatus for generating a pulse line of magnetic force, characterized by connecting a diode in parallel to a capacitance or a controlled rectifier which is used to pass the discharge of the capacitance to a coil member for generating the pulse line of magnetic force so as to absorb the negative voltage produced by the series resonance of the capacitance and coil member.
