antijon
Doug, if you are referring to Tesla's rectifier, or a type of saturable reactor, then I already know what it is. The idea behind that is so far-fetched I don't even know where to start.
Figuera used a resistance for a reason. If anyone here has ever ran a transformer in series with a capacitor, they would know what happens. The inductive reactance is altered, and a transformer stops being a transformer. Now I'm not saying it becomes a generator, or produces OU, but turns ratios and other transformer rules start to change. The problem with using a capacitor to reduce inductive reactance is that it's frequency dependent. But a resistance will do the same thing at any frequency, which is why Tesla used a resistance to start some of his motors.
What I'm saying is, a normal generator uses D.C. Exciting current. The exciter winding has ZERO inductive reactance. So if I replaced the D.C. With AC, what would I expect? A giant inefficient transformer with an incredibly high reactance.
Reducing the reactance is a good place to start. Adding reactance, or using an AC source will give you a transformer.
marathonman
Antijon;
The real question you should be asking yourself is what type of resistance did Figuera use knowing that the patent is drawn and worded in it's most elementary form for comprehension,  thus you are left with wire resistor or magnetic resistor and which one would be most beneficial in the Figuera device assuming it was being used to self sustain and govern it's self with the ability to store a magnetic field for later use.
I really don't think your options are plentiful.
Hanon;
Your not storing kilowatts of energy, just enough to power the primaries and what ever you are using in the function of device. that was your miss interpretation of what was said.
MM
hanon
A table comparing the features of transformers, generators, and Figuera generator and why this has no manifestation of the Lenz effect.
In generators, Lenz is manifested by a dragging in their movement as consecuence of the Lorentz force. In Figuera generator there is no dragging because nothing moves (the induced wires suffer internally the Lorentz force, thus why they must be tightly packed to avoid their movement/vibration). There is no dragging because there is no movement. Lenz exists, but as the only thing that moves are the massless magnetic lines then the work required to move them is almost null compared to move a physical object (armature)
hanon
DA1
 Hi  all
Free energy   in Thai land  4 kw - 1MKW  https://www.youtube.com/watch?v=Jr7yOPmfCCk#t=89.257504
ไฟฟ้าฟรี   ของ ประเทศไทย
   DA1
