0 Members and 27 Guests are viewing this topic.
marathonman
while i do appreciate your though which is genuinely nice gesture, i have been down that road before only to have not so nice people accusing me of misrepresenting myself in which i was definitely not so i unfortunately have to decline that offer.
when you live in the crappy world we live in today where corporate and personal greed is at it's highest where people are reduced to nothing but a dollar sign,  those more misfortunate than i am seem to get to the scraps before i do so i am left with what i can get. i know it sounds crazy but i rely on my self only that way i have no one to put the blame on but me. a hard lesson i just received two months ago was a mechanic said he can fix my truck but 1,ooo dollars and two months later all i have to show for it is a 2500 lb paper weight and loosing my job in the process. try getting back on your feet with a bicycle and tell me how that went. it is a slow process but i am doing it as i was taught not to give up EVER. people in Japan can do it then so can i.
Marathonman
marathonman
I really have to add after reading a few older posts people still don't grasp the concept of a generator. a generator does not produce an unlimited supply of energies to waste as you wish, sorry generators do no operate like that. generator do not generate they bring energy in from the surrounding environment or the dirac sea if you wish (Aether).
Gravity has a three dimensional plain of existence and when exposed to a two dimensional magnetic field it cancels out two of the Gravitational dimensions leaving one Gravitational dimension which causes currant to flow from the Aether (counter space) into the generator system.(space)
now back on track, the inducing side of a generator is a closed system to say. since the residual magnetization in the core is polarized it automatically will start producing electrical energies in the secondary (pulled from the Aether) which is feed back to the exciters from the AVR to produce more energy until it is producing enough to handle the exciters and the external load combined.  once the exciter fields are at maximum the the draw of the exciters are reduced to that of just the IR2 losses to maintain said field.  when the secondary load increases the resistance in the external circuit will drop causing more currant to flow which sends more currant to the AVR then to the exciters to produce more energy until the secondary is producing enough to handle the exciters and the load.
the exciting side of the system is a closed system except for the feed back from the secondaries through the AVR to the exciters. at no time is the power from the exciting system used in the secondary system as that is also a closed system. the secondary and the load is a closed system and once the currant is flowing in the system no other power is drawn from the dirac sea (Aether) because the currant in the system is circulated around the this closed system being pushed around by the interactions of the dirac sea (Aether) from the magnetic fields created from the primaries. if the load is steady the draw on the dirac sea (Aether) is reduced to the losses in the secondary closed system and the pressure to maintain the load.
the currant in both systems is circulated around each system and just the feed back from the secondary system is feed to the primary exciting system to replace the IR2 losses or when the load is increased.
no power is ever used up in any of man's systems, it is only circulated throughout  each but the losses created by heat is non recoverable which has to be replaced.
the cogging effect is then the stator and the rotor's attraction forces (lenz Law) become so strong and the motor boggs down to overcome this effects.
now applying that to your Figuera replication and see what you can come up with in terms of a self runner.
Marathonman
marathonman
I think i seem to have stumbled across the problem everyone is having from reading past posts. in the test performed by myself and electrocute on another forum with magnets we, as in both of us,  attained double the voltage from one magnet alone (post 4206) while another person got diddly squat. why did that person get nothing out of his test??? because of the opposing pressure between the magnets was not high enough for any good type of output. if that person had moved his opposing magnets closer together increasing the pressure and compressing the field lines he would have registered double the output.
this is the very reason why so many on this site are having so much problems attaining an output with electromagnets. This has been posted by me SOOOO many times it is not funny. " if the pressure between the electromagnets are not maintained the inductance will drop and the output will fall to that of the rising electromagnet."
what this means is both primaries are responsible for half the output of the secondary so in order to maintain the output the pressure between the primaries has to be at a certain level and if not there will be no output or very little.
the higher the pressure between the electromagnets the higher the output and this is of course reducing one electromagnet while the other is increasing. this will cause the electric fields to be in coherency which is positive and additive.
for 1 kilowatt of secondary output a pressure of 14.8 lbs per square inch has to be maintained between the primary electromagnets at all times shifted back and forth over the secondary. that means each primary is accountable for 7.4 lbs per square inch of pressure compressing the field lines to 14.8 lbs per square inch.
if you don't have the required pressure you will get squat for output because the Figuera's device uses two primaries to match that of one high intensity field of a standard generator.
what we are dealing with is a duel opposing mono-pole excitation system so pressure is to be maintained at all times. so i suggest you people with no output move those magnets closer together or increase the pressure between your electromagnets and retest and the results will happen. start using the upper region we call a brain and actually read and understand what is posted instead of skimming over. if you so choose to not take above advice then what are you doing here in the first place.
get it, got it, good.
regards,
Marathonman
marathonman
Here is the 6061 Aluminum plug i receive that will be CNC to the adjustable brush holder. the video is the brush holder with movement.
i guess there is no way to post video's here other than a link.
https://www.youtube.com/watch?v=9RCKOuyf1s0
Marathonman
marathonman
WOW ! a good 5 mile bike ride this morning has me all fired up but is is already hot out getting into the 90's, YUCK !.
For those that are a little skeptical or hesitant about making your own bobbins for your cores please don't fret because it is easier than you think. i found craft felt from recycled plastic bottles works wonderfully in this department at 24 cents a sheet 12 x 12 inches.
all you have to do is cut the width you need, wrap around your covered core then glue in place with superglue cutting off excess. you can then cover with fiberglass resin and let cure over night. cut out the ring ends leaving room to slid over the core end then place on non stick surface then cover with resin curing over night. you can then attach the ring ends the next day one at a time coating with resin a few times allowing to dry in between coatings. when finished you can sand the bobbins and paint any color you wish.
now you have your bobbins made you can wind to your hearts content. this tutorial goes for square or rectangle core also just be sure to cover your core with a thin layer of something that will not stick to the resin to bad that you can't get it off.
in the end you will be proud of your self for taking the time to not only learn something new but you will be able to repair your device in the case of an accident or even for another project winding your own coils.
bobbins allow for adjustment and easing the burden of directly winding on cores that is a royal pain in the back side without proper equipment.
Marathonman
