0 Members and 28 Guests are viewing this topic.
iflewmyown
How long would you estimate till your part G is up and running and you are making lots of power??
marathonman
I already have the original replication part G but i have a balancing issue that plagued the replicator that shared with me. my new design is ready to be wound and will eliminate this issue but unfortunately the only CNC in my area is bogged down with work so they cant get to my new brush holder and this really pisses me off. i am trying to have it complete by the end of July as a B day present to myself. money is tight as a Filipino virgin right now but i am hopping i will meet my dead line.
hows your research into the Figuera device coming along or does it exist at all or are you just waiting for someone else to do the work for you like all the rest on this site. just curious as to your intentions as "i" actually know how the device works through my research and bench work.
everything i have described in my posts is "Physics facts" and can be replicated by everyone. ;D :-* :o
Regards,
Marathonman
marathonman
If you people only new the significance of the below equation. it is the reason why the Figuera device Inductor controller part G can operate as it does changing the magnetic field to current ratio on a steady basis. in lamen terms it means if you change in any way the loops in the circuit with the same amount of current you change the self inductance which is the opposition to current flow.
a lot of people still think the Figuera device is Lenzless in which you would be entirely incorrect. in fact Figuera used it to his advantage and knowing any, and i mean any reduction in magnetic field will release that potential into the system which is totally foreign to even electric engineers.(imagine that)
using the reduced potential to Figuera's advantage was and is as i say "SHEAR GENIUS" to say the least when especially when people can't even get past it as a stationary object that has been to a so called college. (i am so impressed)
studying inductance would be to ones advantage to say the least and thinking outside the box for a change instead of being so closed minded. self inductance can and will change the magnetic field to current ratio if the positive brush rotates on a continuous basis. the Lenz law is the magnetic linking to the loop next to it so if you add or subtract loops you are changing this ratio which changes the opposition to current flow so as the brush rotates so does the opposition to the original current flow.
OMG ! did i state a Physics fact, imagine THAT !
Self Inductance can and will change the current flow whether you like it or not so why not use the CEMF to one's advantage. sorry uninformed,  resistors can never in your life time do that.
Marathonman.
marathonman
FARADAYS FIRST LAW:
Whenever the magnetic flux linked with a closed circuit changes, an e.m.f. is induced in the circuit. The induced e.m.f. last long as the change in magnetic flux continues.
notice Faraday's law did NOT say anything about current it just said if the magnetic flux changes and the induced EMF that opposes the original current flow will last as long as the flux changes.
FARADAYS SECOND LAW:
The magnitude of induced e.m.f. is directly proportional to time rate of change of magnetic flux linked with the circuit.
again he never said anything about current change just the time rate of magnetic flux change so by adding more loops that magnetically link to the circuit you are changing the magnetic flux in a time rate of change which is 3600 times a second for the US and 3000 times a second for everyone else.
so any alteration to a circuit which increases the flux (total magnetic field) through the circuit produced by a given current increases the inductance, because inductance is also equal to the ratio of magnetic flux to current as per Faraday's laws of induction.
add all these up and what do you get.???  you get an Inductor with a rotating brush that constantly changes the loop count that magnetically link to that side of the circuit that produces an opposition to the original current flow. as the brush rotates so does the change in magnetic field to current ratio witch is the amount of opposing EMF to the original current flow.
imagine that ! Figuara's inductor controller backed up by Faraday himself. now is that enough Physics fact for ya. Figuera used an Inductor as his controller plain and simple backed by the Grandfather of Physics himself.
Now if that is not "IN YOUR FACE" Physics i don't know what is and have no clue what to do with ya.
Marathonman
marathonman
The 3600 for the US and 3000 for all the rest is the brush rotation speed (RPM) in the above post which will equal 60 hz for the US and 50 hz for all the rest.
Marathonman
