0 Members and 27 Guests are viewing this topic.
endlessoceans
Quote from: marathonman on August 02, 2018, 07:51:41 AM
And you MR endlessoceans would be entirely correct. i just posted the times to give someone heads up how fast the switching is done but in reality it can happen at much, much slower frequencies.
years ago i told a member Hanon that he could hook a Variac up with DC then attach two lights to the output then twist the knob and watch the lights do the same thing as the Figuera device. when he twisted the knob both lights raised and lowered opposite of each other in complete unison which was acting as an active Inductor with the twist of the knob.
the frequency couldn't have been more than a few hertz at best and yet the bulbs raised and lowered perfectly in unison. here lies the problem with most self appointed authorities on this web site " Their brain gets in the way" of proper reasoning and post negative comments because it is outside of their understanding so it must be wrong.  mind you I am not pointing fingers as they expose themselves.
this video is something people like Cifta, Bistander, Seaad, elcheapo, Ranswami, darediamond and the "like" refuse to acknowledge the facts that Inductance can and will control current flow but i won't mention no names. Ha, Ha, Ha !
the reality of the matter in question is the Figuera device used an active Inductor to control the current flow through the primaries at the same time as storing and releasing potential thus all the DOGMA TAUGHT schooling in the world can not change this fact or complete ignorance for that matter.
another person with a brain....... this is a good thing.
regards,
Marathonman
Dogma.....ahh statement so true.   well said!    98% thread content contain Logical fallacies regurgitated and lapped up like its a Michelin star meal.
Your assessment of the Figuera device spot on.
marathonman
I have the original replicator to thank for setting me on this path of enlightenment.
jhewitt03041976@gmail.com;
sorry missed your post.
Wire size is irrelevant but the thicker wire will last longer (can be reworked) and have less resistance which equates to less losses....ie. the most efficient Inductor.
seaad
Quote from: seaad on April 30, 2018, 06:02:11 AM
https://vimeo.com/178144785
Quote from: seaad on May 01, 2018, 06:22:34 AM
Hi d3x0r , All
That stay on lit delay effect is a bit puzzling. And I wonder if the voltage across the bulbs goes higer than the battery voltage? I have tried to simulate this circuit with a 20 steps LT Spice Simulation but it gave no such delay effects. I think we have to build a simple test bed with a real variable transformer. But sadly I don't own such. Maybe someone in the audience here is in the possession  of a variable transformer and can replicate that simple test with an osc-scope connected also to verify the effects? A higher voltage across the bulbs and the delay effect.
MM Quote above: " this video is something people like Cifta, Bistander, Seaad, elcheapo, Ranswami, darediamond and the "like" refuse to acknowledge the facts that Inductance can and will control current flow but i won't mention no names. Ha, Ha, Ha ! "
False!
Regards Arne
citfta
Hi Arne,
I agree.  Anyone with the least bit of electrical knowledge can easily see if you turn the variac control wiper to the far left end, the path of least RESISTANCE is through the left bulb.  And when you turn it all the way to right end of the variac, the path of least RESISTANCE is through the bulb on the right.  Inductance has absolutely nothing to do with changing the bulb brightness.
marathonman
seaad;
It's is good you have come to this realization.
Cifta;
you are wrong as always,  all the wire together has very little resistance otherwise it would get to hot and when using DC through a variac the twist of the knob stopped so did the self inductance and the bulbs grew bright together but when moved induction is taking place that opposes the original current flow.  it really doesn't matter as the Figuera device uses an inductor and i can care less what you or anyone else thinks.
I just so happen to be right and every one else is starting to realize this. their are still a select few that can not grasp changing Inductance over time changes current flow but that is YOUR demon not mine.
Regards,
Marathonman
