marathonman
 When the brush is in motion there will be North><North fields at the brush keeping each side of the Inductor separate. when the brush moves, 3,600 RPM US 3,000 RPM all others, adding one link to that side of the system it is adding to the intensity of the magnetic field , increasing magnetic flux to current ratio, as the current is the same in that loop. when you increase the magnetic field you will in fact cause an EMF to occur which is in exact accordance with Faraday's Laws of Induction. this EMF Induced will be in the opposite direction of the original current flow thus reducing the original current flow as each subsequent loops are added.
as each subsequent loop is added or subtracted to that side of the brush causes an increase or decrease in the magnetic field that induces an EMF to oppose the original current flow. the more loops that are added the less the original current flow, the less loops the more current will flow.
this method used by Figuera is changing the magnetic flux to current ratio which in in exact accordance with Faraday's Laws of induction that simply states there has to be a change in the magnetic field for Induction to take place. so as the brush moves so does the change in the intensity of the magnetic field on either side of the brush causing the reverse EMF to oppose the original current flow.
each time a loop is added to that side of the system the magnetic field will increase and the current flow through that side of the system will decrease and since the current is decreasing it will release that reduced portion of the magnetic field in the form of a potential into the system to off set the rising side of the system.
each time a loop is subtracted from the other side of the system the magnetic field will decrease and the current flow through that side of the system will increase and since the current is increasing it will be storing into the magnetic field for the next half cycle. each time it stores into the magnetic field there will be a potential drop on that side of the system which is off set by the reducing side of the system.
the secondary feed back being just like a standard generator is there to replace the losses occurred and to give rise to amplification to the rising primaries.
in the event of the reduction of current flow through the primaries the intensity of the magnetic field will be reduced thus just like part G Inductor, will release that reduced portion of it's magnetic field in the form of potential combined with part G's reduced potential that off set the rising side of the system. the potential within the exciting system is never depleted and is recycled just like a standard generator system.
each part of the system being the exciting system or the Induced system are separate systems and once the polarization takes place in the Figuera system they part ways and it is just the relative motion of the primaries that impart motion into the secondaries through the coherent Electric fields from both the primaries combined.
Regards,
Marathonman
marathonman
Self induction within the circuit in the Figuera part G Inductor that opposes the original current flow.
EMF=d(L*I)/dt. any change in the circuit either increasing or decreasing will change the magnetic field thus in compliance with Faraday's Laws of Induction.
Regards,
Marathonman
marathonman
If "L" increases "I" decreases, if "L" decreases "I" increases.
EMF=d(L*I)/dt.
plain and simple.
Regards,
Marathonman
Quote from: marathonman on August 05, 2018, 06:57:57 PM
EMF=d(L*I)/dt.
plain and simple.
Regards,
Marathonman
the electromagnetic force written                  =d(L*I)/dt
              the electromagnetic force  written                 = BLI
ergo                                                              d(L*I)/dt= BLI
                            One formula for the physician and one formula for the engineer/technician
                            Volt ? Ampere ? virtual Ampere-turns ? physical coil- turns ? Ohm/Kirchhoff ?
                                                yes,plain=clear for the mind and simple= not complex
but this for a constant force definition
how to calculate an increased force or decreased force variance as kinetic or potential velocity.
Is the variance relativity(=relationship) arithmetical linear or progressive or dynamical.
And least: is there a physical limit  for example a.by material specific values limitation
b. ambiental condition c. ..... et cetera
we as educated humans have in "conventional" maths( in german "Grund-Rechnen-Arten" ) law-limit:
In relations ( maths " division : divident/ divisor) the divisor has "ever" to be greater zero
In physics( multidimensional zero point coordination system with cos,sin,tan) the divisor can be   = 0 analog the car engines " Leerlauf" , RUHEPOSITION(but in motion, consuming)
Nobody,  wo is not "MENGENLEHRE" ( goto search-machine and listen what it is) ducated, understand Plancks Quanten-Paar-Physik(Quantumphysics) cause here you enter the " possibilities"-world from
"myriad= uncalculable many=VOLLE MENGE" to {0} Finally to less than  physical O the emptyness stage { } = LEERE MENGENRESULTAT
comparative with 0°KELVIN stage = absolute Ruhepol
Natuerliche,reale,reelle,rationale,irrationale ,positive,negative numbers-world~
                                         brain/cyber/fantasia/dream-land
                                         peace or war - visionary
citfta
Marathonman,
I sincerely apologize for all the times I said you were wrong.  I believe I finally understand what you are saying.  I watched the video several times and you are correct that the brightness does change a lot when the wiper is moving but settles down when the wiper stops moving.  I have spent several hours trying to figure that out.
I have come to this conclusion.  Yes there is a steady state of current and flux when a DC current is applied to an inductor.  And along with that steady state there is of course a steady magnetic field around the inductor.  When you change the number of turns of the inductor you are causing a disruption or change to that magnetic field and as you have said several hundred times that change in magnetic field translates into a change in the current while that change is taking place.  So as you have said if you keep the brush moving and continually change the number of turns then the current can be controlled by the changing inductor.
Do I finally have that correct?
Respectfully,
Carroll
