0 Members and 27 Guests are viewing this topic.
seaad
Quote from: marathonman on August 08, 2018, 05:17:47 PM
Seaad;
not only that the fields in each half will be opposing thus cancels each other out so no current control at all.
Marathonman
Sorry, you are wrong there no cancellation occurs.
Regards Arne
marathonman
And i am sure you have done tests on this core design. i can tell from the magnetic field circulation that the fields in the core will cancel out. in one half the magnetic field will travel in one direction and the other it will be opposing to the first.
Reassess your situation and visualize the magnetic field before you post as fact. i can see it plain as day.
and please don't hack my graphs and claim it as your design as it is very, very poor taste but then again you have always been at that level of research. i think it's time to make a change.
good luck all the same,
Marathonman
seaad
Hi MM
I'm always making tests before I put out my nose. I don't always rely on Old scientists names.
Instead  I let the nature tell me the truth so I can sleep well afterwards.  ;)
Sorry for borrowing your pic as a starting point.
Quote: "and claim it as your design as it is very, very poor"
-I didn't!   I was claiming 4 x H !!    Reply #4468 on: August 08, 2018, 01:26:55 PM
Only as a suggestion to utilize the full capacity of the core if you want more Henrys from it of course.
Regards Arne
marathonman
I am just trying to get you to realize the wire hanging in mid air will do nothing for the induction and is a waste of wire and money that can be spent on other areas. iron amplifies Inductance up to 50,000 times wire hanging in mid air almost nothing.
Yes i would need to see a scope shot of that set up before i can believe it will work as all i see is two opposing magnetic fields in that set up as the two are in two different directions colliding mid way.
I did not mean to be so snappy as we were hit with 18 pallets of groceries and i had to play Superman for two days. at 55 i still got it but quite sore. use the graph all you want.
Regards,
Marathonman
seaad
MM
Its a bit similar to a current measuring "toroid" with the measured wire hanging in mid air in the origo.
And as you know that arrangement doesn't work!!  Lol  ;D ;D
It's a matter of how many wires passing through the core hole (turns).
To make a test of the principle take two small C-cores some feet of wire and an inductancemeter.
The problem with this comes with all the crossings in the middle not the electrical part, if you have tight (thick) wires running paralell both on top "plate" and bottom "plate" from end to end.
To solve that make two levels of crossing lines. (this is NOT tested at all!)
Regards Arne
