0 Members and 55 Guests are viewing this topic.
Wow, thanks for that Arduino program code... I'll be trying it out myself, it might solve some problems I've been having on another project.
Does our BBcode allow "code" tags?
some sample lines
entered here as program code
Hmm... not really, I guess.
I wonder if the Arduino will turn a 2n7000 mosfet on directly. If so they could be drivers for larger, regular IRF series mosfets rather than logic level ones. Or if it would makes sense to use a bipolar transistor as the driver for a regular mosfet.
Arduinos are so cool, and it's great that they are programmed in c.
kEhYo77
Hi TinselKoala.
The best way is to separate Arduino from possible spikes. For that I would use optical isolation chip, then a regular mosfet driver chip and then any mosfet or igbt you want.
This setup is a quickie ;)
This is a simple schematic for hooking up the coils and a video of my setup.
http://www.youtube.com/watch?v=hC70s3tYaGs&hd=1
Yes, I agree about the spikes.
But I'm getting a compile error on the file.... something wrong in my avr setup, apparently, it can't find math.h, and neither can I, so I'm reinstalling avr....
OK, got the compile error sorted... it was a file permissions issue, scrambled in the upgrade to 11.10. All is well if I run as root, program compiles correctly.
kEhYo77
OK. I need some help.
I've been thinking that if we could build an unidirectional resonant LC tank on both primaries it would benefit the design.
NOW. The question is:
How to make a switching circuit, that after a one way discharge, when C reverses polarity and a flow of current falls to 0, the circuit would FLIP the capacitor's polarities,
so instead of the current to go backwards it would go the same direction once again.
ANYONE?
