marathonman
That is yet to be seen as you are counting your eggs before they are hatched.
the commutator is the secondary feed back to the system. the double slip ring is because i couldn't find a single at the diameter i needed.
and no i have not attacked anyone just stating facts. one person saying you deciphered the Figuera device is laughable at best when it took you 6 years just to grasp part G so i really doubt your claim you know more than me. i personally don't care.
the person that deciphered the Figuera device was on this thread but everyone ignored his information and advice but me.
Oh, i am very happy you finally pulled your head out your back side and i really hope you get that thing working but don't think for one second you deciphered the Figuera device as that was already laid out in COMPLETE DETAIL.
if i wasn't attacked so much in the past i probably would have finished by now but because of it i had to get away from everyone for quite some time to clear my head and regroup. money is the next obstacle in my path as it has been very tight thus spending a month or so just to save up to buy a part i needed. this tends to slow a build down quite a bit. not only that my triplet cores were dropped destroying the primaries so a complete rebuild was at hand adding more time to completion. i then realized that even though the toroid part G worked it was very buggy from the paralleled Inductance on the non active side causing the balancing issues which i shared with UFOP. i then through research found out that a closed core C would work just the same with a little more losses thus was ran in a sim and it was spot on with no paralleled Inductance. this is where i am right now rebuilding part G with a C core.
just because i don't have a lot of money to build with does NOT give you or your cohorts the right to slander, belittle me or anyone else for that matter. do you honestly think your 2 minute apology makes up for 6 F-in years of abuse from you and your low life friends. i think not and my guard is still up.
Good luck with your build just the same.
Regards,
Marathonman
marathonman
creasysee
Quote from: marathonman on August 29, 2018, 05:27:25 PM
First pic is the paper between layers of double layer up and back.
second pic is completed primary.
Regards,
Marathonman
Hi Marathonman!
A few months ago I did not believe in Part G. Now, with your help, I believe. Thanks!
Can you clarify, please, why your primary coil has more than 2 leads? Why are they wound in several (4?) layers?
Thanks!
marathonman
As you can plainly see from the above graph and my video on youtube of why the primaries have to be NN. with N S the electric fields will be opposing as will the current flow thus having a transformer effect as the N and S fields will combine. this will NOT maintain the needed pressure between the primaries.
Below is a shot of the perfect tool for the job allowing me to get into the tight spots. this Octo from Skill came with 8 or 10 attachments and this one is perfect for bobbin making. i just wish i had a third arm and hand some times.
Regards,
Marathonman
marathonman
one more sanding then a final coat she will be ready for winding. very nice flat ends i might add.
I will post a build of a square bobbin just to show the readers any size or shape can be made using the materials i use for the bobbins.
the bottom pic is all the materials i need to make my own bobbins aside for a marker and some scissors.
Regards,
Marathonman
