marathonman
Self Induction, Faraday's Induction Law and the Lenz's Law
Self-inductance basics;.
When current passes along a wire, and especially when it passes through a coil or inductor, a magnetic field is induced. This extends outwards from the wire or inductor and could couple with other circuits. However it also couples with the circuit from which it is set up.
The magnetic field can be envisaged as concentric loops of magnetic flux that surround the wire, and larger ones that join up with others from other loops of the coil enabling self-coupling within the coil, flux linking as you will.
When the current in the coil changes or the magnetic field associated with it changes, this causes a voltage to be induced in the different loops of the coil - the result of self-inductance.
Faraday's Induction Law;
Any change in the magnetic environment of a coil of wire will cause a voltage (emf) to be "induced" in the coil. No matter how the change is produced, the voltage will be generated. The change could be produced by changing the magnetic field strength, moving a magnet toward or away from the coil, moving the coil into or out of the magnetic field, rotating the coil relative to the magnet, etc
Lenz's Law;
Lenz's law states that the current induced in a circuit due to a change or a motion in a magnetic field is so directed as to oppose the change in flux and to exert a mechanical force opposing the motion.
Lenz's Law applies to self inductance because an induced current has a direction such that its magnetic field opposes the change in magnetic field that induced the current.
So now put these together with the Inductor controller used in the Figuera device and what do you get. you have an active Inductor with a moving positive brush that changes the loop count dynamically on either side of the brush as it rotates that changes the magnetic flux to current ratio. what this means is the magnetic field on either side of the brush is constantly changing either up or down in intensity which according to Faraday's Laws of Induction will produce an EMF. since it is created within the circuit according to the Lenz's Law it will oppose the original current flow thus reducing the current flow to what ever level you so choose according to your build requirements.
so according to Faraday's Laws of Induction all that is needed is a change in the magnetic field.  so when the brush rotates the loops added to the circuit is increasing the magnetic field and it is this field that creates EMF the opposes the original current flow.
all movement of the controlling Inductor produces an Opposing Emf on either side of the brush that reacts with that side of the circuit which allows either side to be in complete Unison with each other but remain completely separate at all times thus allowing set N and set S Electromagnets to increase and decrease in intensity 180 degrees out from one another.
this action allows the Electric fields associated with the Electromagnets to be in the same direction being positive and additive. this is accomplished by using two opposing North face Electromagnets. sorry folks this action can NOT happen with a North and a South Electromagnet.
Regards,
Marathonman
Dave1148
According to the above post  i cannot understand how it produces a positive and negative wave to complete a cycle of sine wave !
marathonman
With the secondary opposing field in between the primaries as they sweep from side to side.  this action causes the poles to flip every time they sweep from side to side.
I have posted much information about this in many posts in the past.
Regards,
Marathonman
marathonman
 Dave1148;
  Reading some of the past posts will help in the understanding. any questions just ask.
Regards,
Marathonman
marathonman
After one gets over the fact that Inductance can and will control current flow the system really makes sense. storing and releasing the potential on the exciting side of the system then using a portion of the output to replace the losses and to give rise to amplification to the primaries was sheer genius on Figuera's part. after the initial polarization of the secondaries no power is used there after from the primaries and the potential is to say, "recycled" through out the exciting system. from the inherent ohmic losses the secondary is used to replace these losses with an added boost at the peak of the rising primaries to maintain the needed pressure between the primaries to sustain the output.
Regards,
Marathonman
