0 Members and 57 Guests are viewing this topic.
Sam6
After posting the spreadsheet yesterday, I discovered that I had omitted the excitation VA/lb from the losses. Including them lowered the calculated COP to 98.43. :(
The newly posted spreadsheet has that corrected, and some of the cell comments have been clarified. The project description dated 4/20/19 has the updated dimensions, output  KW, and excitation voltage for the generator.
Please accept my apology for the error.
Sam6
bajac
Sam6,
I think you are right on the size of the electromagnets. For a while, I have been convinced that the Figuera's device was huge, not the 8-inch long core that I built. I agree that a large iron core should definitely be a plus. Though, I am not sure about departing from Figuera's teachings for providing small air gaps. In my opinion, the air gaps are needed. But I would welcome you to try your large size coils since it should be a huge learning experience. I would suggest to build it in such a way that it would easily allow you to test both, with and without air gaps.
Has anyone found any record about the size of the Figuera's electromagnets? I think it is time for us to put together a list of all the clues we can find about the Figuera's device. Seeing all the clues in one place may help us to brainstorm and to look at his device in new and different ways.
Thank you,
Bajac
seaad
bajac
You don/t have to put together a list.
Just sit still in the boat and watch what Aetherholic and Marathonman are doing and watch their equipment in this thread: http://www.aboveunity.com/thread/clemente-figuera/?order=all#comment-113491cc-bb60-469a-9725-a88f0122b9ec
Aetherholic sayed he was burning about1800 Watts into something, ??? the primarys ??? for 20 minutes but didn't mentioned how great the output power was. Something must have become hotter than 1800 Watts because he talks about amplification.
NRamaswami
I beg to differ from many members here.
I believe that how these devices operate is known to many members who don't want to say anything out of fear.
Our good friend Marathonman is on record on this point
Please look carefully at Figuera device patent drawing. The output from the switching component part G is send through a resistor array. What will happen?
Voltage will increase and current will be diminished. This array is almost an oudin coil.
In Tesla coil the primary and secondary are wounding opposite directions. Current enters the beginning of primary and the end of the primary and beginning of secondary are earthed and current rotates I opposite directions. Therefore there is virtually no current I Tesla coil. In oudin coil the voltage is boosted in a similar way but the primary and secondary of oudin coil are coiled and current rotated in the same direction. But there's a very significant voltage increase.
Let us say that inputs a 13 volt 8 amps battery. The switching unit part G or MOSFET makes and breaks current. The one that comes outgrows through the oudin coil. Voltage is boosted 100 times. Current is similarly reduced by 100 times.
In Figureas arrangements the voltage keeps increasing and current keeps diminishing.
So how can you get output?
The primary cores are all permanent magnets already. They have their own magnetic field. This field is static. It is oscillated by high voltage. Over this you wind the output coils.
Output = strength of the oscillating magnetic field X voltage X frequency
The poles are nsnsns only. Te gap is to cool down the permanent magnet core. Nothing else.
If you look at Figuera device arrangements one pole has relatively higher current and the opposite one relatively higher voltage.
If you use a single iron bar only frequency from 500-1000 Hz should work.
If any one tells you to avoid high voltage and use only soft iron rods try are deceiving you. Permanent magnet core and multiple rods and NSNSNS arrangements.
Where is the feedback coil?
The central coil is the feedback coil. Use permanent magnet core and it will produce induced output and step it down rectified it and supply DC to the input.
How man
As many as needed to match the initial feeding battery.
You will need a MOSFET and Arduino to gate the MOSFET. For a single piece ordinary iron we found that response cooked up to 1000 Hz.
What is the possible output?
It depends on the number of primary output coils, voltage on them, frequency applied, magnetic field strength of primary magnets.
You can test them yourself. I am not well. I the last five to six years I have gone through one problem after another problem after another problem. Heart attacks,, stroke, asthma, diabetes mellitus, epilepsy and TB.
To a person like me who is struggling what is the use of threats? Nothing.
This is the secret of Figuera device. Not part G .not Air gap this and that.
You don't have to believe me. Check it out yourself. But very careful. High voltage at low frequencies is very lethal. Not just the voltage by also the magnetic field. You must put very high safety precautions before doing this and I am not  asking you to test this. Any experiments you do would be at your own responsibility.
One friend from Romania asked me many years ago to disclose the secret if I come to know of it as their country is very poor very cold and is struggling with oil bills. I hope by disclosure made here I have served humanity.
Thanks to all
I will not check my messages nor will I respond minor do I intend to post. The persons or teams that brought out this hidden patent must get the credit.
Ramaswami Natarajan
forest
Why do you insist in replicating this device ? it is complete waste of time. You cannot do it. It's like saying you can become a master of kung fu just by reading a lot of books about it.You must start to think like Figuera and start from what Figuera started before 1902.
The best way would be to gather all information about Figuera from places where he lived. Maybe you can find a picture of his generator prototype  - even a single one would be tremendous move forward.A little toy can be constructed by using strong magnets and a closed magnetic path but the output would be barely OU just enough to keep us interested - I will leave it to somebody else I have no mechanical skills or time or money. Just think - it is very easy device, I'm sure it can be build but nobody seriously is interested in it because it breaks the current status quo....
