0 Members and 55 Guests are viewing this topic.
bajac
I noticed some disappointment and frustration going on with some members. It can happen, but we should not give up our dreams and hopes. Last night I was watching an interesting YouTube video about SpaceX that is inspirational. The video is about of how Elon Musk was able to pull it off even though most of the people were not supportive and many failed experiments:
https://www.youtube.com/watch?v=FbzegGHkk8c&t=15s
A very important rule to working as a team is to show respect to others who are also spending time and resources toward a common goal. If someone thinks he has an idea and wants to build it his way, we should welcome this effort and avoid stupid arguments and hard feelings that will only get us nothing.
I will make one more push, but this time I am going the whole nine yards. Instead of building a single set of electromagnets, I will construct the seven sets as shown in Figuera's patent. In addition, I will do it with larger iron cores. My budget is tight so I started planning.
Thanks and happy experiments!
Bajac
ramset
N Ramaswami
I salute you sir
while I cannot tell from your post if you have actually succeeded , your intent is clear and your purpose received .
We need more such awakenings if we are to ultimately succeed .
Respectfully
Chet
Thanks Grandma
NRamaswami
Hi Chet
Let's avoid the saluting business. No need for it. We are all doing what we are destined to do.
Let me put it this way. There are many knowledgeable people in a particular place. Most are afraid to even say they are knowledgeable about truth.
One such person X is struggling for money. I said hey.. I am also a beggar and I can try to share something in my pocket with you. Then X said if you send any money I will get into trouble. and Begger Y is trying to get some help for me but I will not take any thing from you. Reality is all are beggers who depend on God for our day today survival, health, knowledge, money, ability to work and mind to share with others. No saluting business please. Incidentally you know both beggers X and Y.
On November 8, 2018 I was on fasting for a religious ceremony, suffered a stroke or epilepsy attack and became unconscious and had to be admitted to hospital. I did not know how long I will survive. I then decided to make it public.
In the Figuera patent you would find that there's no mention of defeating Lenz. Pray tell me where he is talking about it.
What's Lenz law..
The secondary coil tries to oppose the rotating magnetic field and it needs to be overcome for electricity to be produced.
So in turbines they use water or steam to rotate the core itself and it is called conversion of mechanical energy to electrical energy. This conversion results in loss and so more mechanical energy is needed to produce less electrical energy. Same with cycle dynamos.
On the other hand by using Tesla coil or Oudin coil in series you can create a lot of voltage. Voltage is powerful driving force. There's no water weight to give current. Ok. Only potential.
Wind this high voltage coil on a large permanent magnet core, you make the static field into a rotating field. We have 10 watts units producing 50000 volts at high frequency. We can have any frequency we need by modifying capacitor resistor values. You know it.
A normal low cost permanent magnet core material is soft steel. You have to make it a permanent magnet first.
You know how to do it.
Then wind high voltage wires on it and keep increasing the voltage and send the wire in series on several permanent magnet cores.
Take output coil from each core separately and use it. One of these cores can easily produce between 2-3 kilowatts on load. A normal induction coil using soft iron rods which have no permanent magnetism can produce 91-98% on load as tested by us many years back. Input was 220 volts,50 Hz and 15 amps. Output lit up 17*200 watts lamps but output was only 300 volts and 10 amps. We could have increased the voltage to 350 volts and 11 amps also but we used to disbelieve that as metre errors. This result depends on input voltage and we have voltage fluctuations here.
Ok..now you take that 300 volts after powering the output and use it provide power to primary of a Tesla coil to increase the voltage to 3000 volts in Tesla secondary and wind it on a permanent magnet core. You know in Tesla coil the current is destroyed in secondary and voltage alone is increased. Same frequency. Now what will happen if you wind high voltage Tesla output coil over the permanent magnet core? Look there is no current there. The magnetic field is no.longrr static. It is oscillated. If you wind a step down coil over this permanent magnet core you get output.
Here Lenz law is not violated. There's no violation of law of conservation of energy.
Output= voltage applied in primary coil+ thickness and number of turns of secondary coil +induced voltage in secondary coil+  size of the permanent magnetic core and magnetic field strength + frequency. Ordinary permanent magnet core material works upto 500-1000 Hz. Not all materials are same but it is a safe range for most.
Very cheap material only. We can oscillate the output to desired Hertz by suitable means.
Actually the Figuera patent is misleading. The magnetic field strength on both the  N and S magnets should be equal for the central coil to provide the best output. You make one strong and another weak the output in central coil comes down.
There's no mention of need to wind output coils on primary cores and need to provide high voltage or that the primary cores must be permanent magnet cores. But a person skilled in the art can identify that easily with a little experimentation.
He has hidden as far as possible. But with suitable coiling every thing he has claimed could be done. In his time what was required was demonstration before patent office if working device. Not enablement of competent third parties as required today.
He has also shown the feedback coil as output coils connected in series. He has fooled every body with this. The central coils are feedback coil and they must be connected in parallel to provide DC input to the + point of part G. Today we can replace part G with a MOSFET and use suitable gating means on MOSFET.
It took me a lot of time, money and efforts to understand all this.
I have disbanded my team. Poor health, lack of money to pay them all and hope that at least some one else or more continue with what we have learnt.
As Forest says it is a simple device but he will not do it for he has no money.
I think there are many people who can do simulation here and let them say it is all fraudulent and cannot work. You can also do it and find out if it would work. I rarely find experimenters willing to put their money where their mouth is.
Ramaswami Natarajan
forest
You misunderstood. Yes, I have no money less then enough to build it but I have also no tools and skills. But the main reason I posted is the fact you all avoided Figuera path. That is the road to false theories. Don't build the final device from 1908, build one from 1902 and find Figuera road!He took ordinary generator and modified , rewound and found all problems which  still today make generators inefficient. Then step by step he fixed them , however without going this step by step you cannot make any progress. The first step is the most important one I think.
Lenz law....well let me ask : what is the reason of winding coils tightly and closely to the generator rotor core ?
NRamaswami
Forest..
Please understand that I have neither any interest nor health nor any money nor motivation to do anything further.. I have not done anything in motors and so have no knowledge. Without doing something and experimentation how can I either ask or answer questions? I honestly can't.
I have no interest nor any intention to post nor any further information to share here.
Thanks..bye
Ramaswami Natarajan
