IMIGHTKNOW
I guess people do not study physics on this site or OU apparently. There is no way to vary a north and a south magnets or electromagnet as they inherently join as one magnetic field. Reducing one and increasing the other with the type of switching in the Figuera device is darn near useless. I tried it for months with an outcome of very little every time. There is even an uninformed person on OU that is trying to use AC in this device and that is completely useless also. Not one physics professor or electrical engineer uses an AC electromagnet because they are inherent slow to react. The inductive reactance and flipping of all the magnetic domains is very, very time consuming taking a lot of power to do so. Plus when it just starts to get to a point of usable magnetic field strength it reverses and starts the flipping all over again. Not to mention the hysteresis which is another major blow attempting to use ac.
This is insanity to think ac can be used in this situation and the reason why every exciting field coil in the world of every standard generator is DC driven. So the facts remain that it can not be a north and a south electromagnet or ac driven. It has to be opposing being swept from side to side over the secondary using DC.
Why people do not follow the patent is beyond me. It also stated the patent is just a drawing for the understanding purposes OLNY so why do people still think resistor or resistor network are used in this device. IF it says that R is just for comprehension then what other viable solution can there be to control current flow in the most efficient manor possible.
An inductor and inductive reactance is the only viable solution according to physics.
Apparently you are forgetting the person said it LOOKS like the egg of Columbus not that is was which is your fallacy not mine. ;D
IMIGHTKNOW
Hers is a video I found on Youtube that shows two lights being switched high and low just like the Figuera device patent states 180 degrees out from each other. Just so happens it is an inductor using inductive reactance to control current flow. ;D
https://www.youtube.com/watch?v=gu5u4wVgiw8
Cadman
floodrod
Couldn't help myself and had to attempt to build it...
5x H-bridges
4 resistance coils
1x triple layer transfo
Arduino
Firing 1-2-3-4-5-5-4-3-2-1 repeating.  One polarity pulses.
I recorded what the scope looks like. Both repel and attract modes.  https://www.youtube.com/watch?v=bCRyBpUy0jA
I will continue to poke at it.  Considering winding more tranfo's ..
Planning to test alternating DC, different frequencies, and whatever else I can muster.
EDIT-  here is a video of the firing order- which I blew all my LED's out.  lol..  The working model is operating on a much faster frequency.  This was slow so we can see the circuit firing correctly   https://www.youtube.com/watch?v=T2Fv3xQslso
floodrod
OK figured out my problem.  H-bridges needed diodes on each hot leg output ..  H-bridge changes then to "LOW" when not used and becomes a ground..
Installed a diode on each H-bridge and now it looks a lot better.  Can clearly see where it goes 5/5 and 1/1 for the reverse.  And the steps are coming into view..  The patents say output is "Alternate" current..  Using N/N I do not get alternating..  But with N/S arrangement I do..
Now shorting the output does raise the input.  So Lenz is not bypassed here.
I think I need lower resistance coils..  Impedance is too high with these coils that the "steps" are in the dungeon..
