0 Members and 51 Guests are viewing this topic.
a.king21
It's just dawned on me why this device will work ou.
Figuera is mixing DC with AC on the collapse of the magnetic field.
This is a known OU phenomenon and was used by Carlos Benitez in his patents!
So for this device to work you need to have pulsed DC (or even ordinary DC)  mixed with radiant energy generated AC.
Good luck. I am really interested now.
Quote from: a.king21 on January 02, 2014, 07:35:20 PM
Bajac: In theory the Figuera device should work. The big question is of course is it ou.
Good luck with your replication. Good science is always worth learning about.
Please post your results.
All the best.
In theory, theory and practice should be the same. In practice.... they are often different.
bajac
King,
It has nothing to do with radiant energy/electricity. I already explained in the published article how overunity can be achieved by fooling the effects of the Lenz's law. However, the paper does not explain where the extra energy is coming from. But, do I care? Not at this stage.
I highly recommend you to read the article.
Whatever we are doing here has enormous implications. I am pretty sure that the physical model that scientists have put together to explain the laws of nature and the universe is wrong because they do not take into account these overunity phenomena already proved by Mr. Tesla and Mr. Figuera.
Bajac
Doug1
Bajac
    There is no extra power needed. Power is a measure of a reaction like work done results in what ever was the objective. The extra power is not an extra just a better use of the power you start out with for a period of time in such a way that where the potential is lower after performing some work it is tricked into providing a reaction which is large enough to satisfy the continuation of the work being done through transformations or translation depending on your use of the word. At a high enough level to prevent anymore of the source from entering the system If you assume a 1 to 1 ratio of power used compared to work done or less then you have to assume the system was designed that way for economic reasons. Everything learned for such a system that uses continuous input will not support anything different.
  Have you measured potentials yet in the load circuit? If you plan to use the load as a source after the start up you will have to be very intimate with every inch of the load circuit. Treating it as a group of magnetic events per cycle. In order for the device to have a self acting field strong enough to prevent any incoming source current you'll need two equal magnetic fields where you would normally think there is one. The second one is not supplied with an equal amount of current as the first but still it has be magnetically just as strong as the one tied to the source for it to induce into the inducer enough field strength to translate back to the load. The load becomes the source when the reaction can be magnified into a larger event with no more then is left at the end of the event in terms of current or potential.
When it is right it will work anywhere anytime on everything. Every living thing that ever was or will ever be is your model.
shadow119g
Well I spent all morning getting pictures on line!
I am building the "OLD SCHOOL" version of this device. The pictures show my "resistor." This is an
electric heater that I bought at the biggest store chain in the us. The price was under $20.00. If
needed I can put the core back into its original plastic housing and use the fan to cool the heating element.
I made a drawing of a sign wave superimposed on a graph of squares on my computer. Across the top is
time moving from right to left. Down the left side are ohms from zero downward to around forty-two on the left.
As you can see the values on the paper indicate the actual values I obtained by using my ohm meter.
I am currently, after getting the pictures online, making a new attempt to only have eight spaces for time
across the top. I believe this is what the Mr. Figeura had in mind.
Swamp
