0 Members and 45 Guests are viewing this topic.
NRamaswami
No problem. give me two weeks time and I will rebuild the device and show the proof live if you want on the powerful magnet stopping the current to go to load.. This looks certainly ridiculous but I'm not able to understand why it happens and this is why I stated this..
I can also show live the results of the figuera device output. But I will reduce the number of turns to reduce the voltage to less than 500. When the voltage is reduced the amperage would also be reduced. But I guarantee that the output is higher than the input..Figuera did not cheat and there was no need for a professor of his calibre to come out with false statements.
I'm not a regular poster and I have a number of clients to serve and when time permits I will rebuild the device and post videos of on youtube and here. It is not a problem.. However if you are regularly in Electrical Engineering I suggest that you also do the experimentation and see if the results are replicated or not..
Quote from: NRamaswami on February 15, 2014, 08:42:49 AM
Many thanks for accepting at least one of my statements that I'm not an Electrical Engineer.
I used a ready made 50 volts 16 amps step down transformer to do the experiment. It did not work when covered in the way I indicated.
The other large 18 layer device produced very strong magnetism but the current would not go to the lamps and power them up.
As I said when I time and money are available I do the experiments out of interest. I have tried to replicate the Alfred Hubbard device without success todate. However I do know one thing. The outer 8 coils are wound in this fashion. the first four coils are wound in clockwise direction and the next four coils are wound in ccw direction and only then in all the 8 coils magnetism is produced. Otherwise magnetism is not produced in the last four coils.
I will check your statement on the alternators working in space. My knowledge is limited and I continuously learn.
There is no intention to teach and only intention to share the results.
I strongly suggest that if you can handle high voltages and high amperages, please replicate the experiment of Figuera as described by me. And see the output voltage and amperage. And please be honest with results.
No, I will NOT do your homework for you! I challenge YOU to demonstrate any thing you have claimed.
Here are some of the claims you've made that I would like you to support with demonstrations or references of your own.
-Transformers will not work without iron or other magnetizable core.
-Generators don't work in vacuum.
-No electrical devices work without access to atmosphere.
-Wrapping a transformer in copper and plastic will stop it from working.
-The Amplidyne is self-sustaining and produces more output than input.
-Magnets eat electrical current.
-No current passes through your "18 layer quadrifilar iron rod" whatever device, even though the wire is continuous and not broken somewhere.
They look rather formidable when all gathered together, don't they. Just pick an easy one and demonstrate the validity of your claim.
QuoteInteresting thing is output is 630 volts and 20 amps at no load. I will need to take an electrical engineer and custom built a transformer to step down the voltage and then see if it can be tested to see if the amperage wattage shown is real. Until then let me keep quiet.
How do you get 20 amps output... if there is no load?
I am afraid you are way over your head here.
NRamaswami
This is actually a punch to me really. Earlier in posts Farmhand has claimed that a device cannot produce more output than input. Now you provide the proof that a device can provide more output than input. Why don't you show a video of your 30000 watts output transformer in youtube video for a 75 watts input..for the benefit of poor souls like me. Since it is your claim you can demonstrate it.
NRamaswami
Please check my first post. We got 630 volts and 20 amps in the Ammeter at no load. Since this was way too high for us we stopped. We need to build a transformer to step down the voltage to around 200 volts and then give it to the load lamps to check. Secondly I have had
50 Amps Ammeters burning out after showing 50 amps at no load. I would not believe that there was amps at no load if the Ammeters had not burned out..
The 4 sq mm wire is rated only for 24 amps. So we needed to buy a very expensive transformer and provide safety set ups. The Electrician who participated in this experiment passed away due to illness suddenly. So we kind of stopped all these things for a few months now.  We have also put up a small website www.tmptens.com where we are coming up with a different effort.
I can provide full description and show what we did and send you photos and if need be make videos. If you can handle the high voltages and high amperages, you may try to do the experiment. Given that you describe a very expensive transformer, money may not matter you. If you can replicate the experment please do so. I have funds problem and I will need time to redo all this. I have the wires but I have to hire people and redo the wiring manually. All wires are plastic insulated wires.
None of the statements are false. There is no intent to teach but only an intention to share the results. You can check it yourself and then let me know.  You appear to have access to good funds given your description of your transformer. That is in short supply here at the moment.
