0 Members and 87 Guests are viewing this topic.
Doug1
Position A = If you slid the coil between the north and south magnets you would not cut any more or less lines of force. If you strengthened the or weakened the magnets the coil would not cut any more or less lines of force.The lines still thread through the coil just stronger or weaker.Best you could get is a piss poor transformer. The coil when rotated changes the amount of flux it cuts and the number of lines.Till it reaches position C and is now facing the other way and continues to turn and the effect is reversed. A and C are simply a way to get rotation to reach B and D. Get rid of A and C.
  Treat the N and S magnets as the motor. If you face the magnets N,N or S,S you have obviated another rotation.That is the magnets do not have to swap poles N,S/S,N because that takes more work.The point where the two fields meet will have a shear line seperating them like two window fans blowing at each other.The air will circulate around the fan like discrete bubbles circling each fan. The center point of collision of the air has two opposite direction of flow. If your hand is more close to one fan it feels the air flow and direction from that fan and if closer to other it feels the opposite. If the fans are alternately slowed down and sped up the collision/wall will move side to side. There will exist a positive pressure between the two fans all the time.
N-S< (induced) >S-N. The induced is AC the poles in the induced alternate. The induced is not consuming of the inducers. The only consumption is the initial power used to establish the fields in the inducer magnets. After they start shifting they sustain themselves the same way any ordinary generator does with movement,you do not input current into a generator from a outside source while using a gas engine as a prime mover to generate electric do you? You just pull the cord start the engine and poof out comes the juice. Long as there is rotation or movement it will expand to it's effective limit and pour out the good stuff till you do something stupid or neglectful to stop it.The real question,the right question is how does a generator work in the first place.Because it does in fact get more magnetic field out then it started with even though no one added any current or greater field strength from an outside source. If something is not true today then it was not true yesterday and wont be true tomorrow.
Doug1
Sorry about that image garbage at the top of the post.It's not letting me in to edit it out.
I will keep trying.
gyulasun
Quote from: Doug1 on February 23, 2014, 04:20:18 PM
I will keep trying.
Hi Doug,
You try to click on the Modify icon in the upper right hand side of your above post, right?  If it does not work, click on the Report to moderator or write a personal message to hartiberlin perhaps.
Gyula
EDIT  you have just solved it, ok.
SolarLab
Possibly useful related background information... since some of you fellows may not be familiar with:
Vladimir Utkin
http://www.free-energy-info.tuks.nl/VladimirUtkin2.htm
http://free-energy-info.co.uk/VladimirUtkin.pdf
He does investigate, amongst other things, Back EMF suppression in a resonance coil using a single Primary with two Secondary windings - but NOT two Primaries with a single Secondary. Somewhat enlightening in any case!
NoMoreSlave
hi dieter,
QuoteJust out of curiosity and since I have an old, 2phase 3 motors steppermotor control card (smc 800)  here, did anyone in here actually manage to get this thing working?
I did not got to work, I m testing it with a 12 VDC nut it is rectified, and i got a sine wave in the output even if ther is no rotation of the commutator, so i have to buy a bettery to see how the signal looks like with a pure DC input...
Beste regards,
NMS
