marathonman
Very interesting reading. could be of great importance to this project plus good reading.
Core Coil and capacitance are critical variables in the OU transform. In order to obtain an EMA class C
amplifier, the magnetic component must correct the PF of the inductive and capacitive ones, at a given CORE
impedance where the ENERGY transform occurs. In AC is FULL resonance, in DC is half resonance states
where pulse becomes a logarithmic voltage gain from a discharging coil & or core into a capacitor where it
becomes a POWER vector (potential) extracted from the 0 point of resonant opposed curvature.
If voltage is maximal current is 0; if voltage is 0 current is maximal. These states create SPACE vacuum and
space tensor where energy compresses and relaxes. In theory 2 off phase identical LCs in common grounded
circuit must create potential differential relative to their space-vacuum states, being those captured such devices
extract energy from thermal and electron spin ones (transformation with possibility of self sustaining and
extraction of energy).
Of 9 types of electricity humanity knows only 2 and has only learned to use one in its more primitive forms.
here is the PDF "Radiant Energy and Over-Unity" Dan Combine.
marathonman
I might have come up with a solution to everyone's delemma.  attached is my idea of the figueras core set up and the PDF where i got the idea. it fits with Figueras design parameters and is Lenz less.  i have a hard time writing what i'm thinking, this is why i have to visualize.  dissect and inform please.
dieter
Marathonman, I was reading this patent, 27D. I am not sure if I understand this "Lenz-less" thing right. The counterforce to induction is the Lorentz force, is this what the patent is about? If so, why is there no Lorentz force?
gyulasun
Hi NRamaswami,
You wrote:
What is magnetic flux cancellation.. I'm not able to understand it.. Please clarifiy..And what is addition of magnetic fluxes and how do these both are done and please give  me examples.
On flux cancellation: I do not think flux simply disappears (or whatever similar word is used) when the term flux cancellation is used by many people, rather I believe the resulting strength and the effect of two (or more) fluxes reduces to a minimum. It is important to notice that no matter what,  the flux from a given current in a given coil is always created and of course you can create a 'counter' flux which either substracts or adds to the effect what the first flux would manifest alone and this interaction can take place very close to the first coil windings if you create the 'counter' flux very close to the first coil.
For example there is the bifilar winding style for 'inductionless' wire resistors to minimize the self inductance of wirewound resistors. You first fold a given wire length into half and start winding a coil with the dual wire close to each other, see illustration attached. The ends of both wires will be the coil connections, and you could measure a very little inductance (say under a microHenry with precise windings) between such coil connections with an L meter, considering the total wire length used.
A compass or a Gauss meter would show a much much less flux intensity at the ends or at the sides of such coils, versus the case when you would use only the one half winding of such coil by making the connections to it between the folded back start and any one other end, using the half wire length only. (OF course you have to use insulated wires so that the adjacent turns should not have electrical contact with each other, and also half input voltage when you test the flux created by the half wire length versus the input voltage used for the full wire to insure comparable situations.)
I also uploaded a measurement on the poles of two magnets when they are 1) separated, 2) attracted to each other and 3) positioned close to each other in repel mode. A Gauss meter was used and you can see from the Gauss numbers what member Bajac nicely described to you. The Gauss measurements in the drawing I uploaded was not done by me.
On flux addition: if you can direct flux coming from two (or more) independent sources into a common permeable, low reluctance material, then you can add (or even substract) those flux sources, a Gauss meter would show the increase or decrease with respect to the original strengths. See for instance the parallel path technology, read Josh's research paper with the measurements: http://www.flynnresearch.net/young%20scientist/Josh%20Jones/josh.htm
Years ago I tested a small electromagnet and increased its strength by attaching a permanent magnet to the core, see this link how it was done in an old patent: http://www.overunity.com/1621/magnet-motor-idea-need-feedback/msg16347/#msg16347  and here my additional notices: http://www.overunity.com/1621/magnet-motor-idea-need-feedback/msg16889/#msg16889
Gyula
