Thanks to ALL for your help!!
Naphtalen in your gas tank ? 30 % more mileage ?
Started by hartiberlin, July 29, 2006, 04:16:12 PM
pg46
Hi-
I ran another careful mileage test today using the motorbike and the mothballs in the fuel. I put the mothballs into the fuel and let it all sit overnight. Same brand of fuel with the same 91 octane driven over the same course.
Once again I unfortunately did not register any gain in fuel mileage over the untreated fuel and in fact I had a bit less fuel economy than yesterday's run.
May give it another test run or two in the future but there was no miraculous gains at least not in my application. I hope it works well for you others as I think its worth a try at least to find out.
Best,
hartiberlin
@pg46,
maybe youir motor is already thus efficient, that it does not
bring much more efficiency in your  case.
As you get over 65 Kms per Liter this is indeed a great
efficiency.
Maybe you can try with adding 1.5 % Acetone and let us know.
Many thanks.
pg46
Hi hartiberlin-
Yes, my good little Honda motorbike is doing real well already without modifications. Last year I did a couple of runs on acetone but only recorded a tiny gain in the fuel economy which when calculated wasn't worth continuing to purchase the acetone.
Here below is something I want to check into as I know someone who has tried this with some good results. Someday when I am not so lazy I will pull the heads on the Honda engine and give it the same treatment. Have a look -
http://somender-singh.com
Hey, maybe I can try the mothballs and acetone together. What do you think? sounds like a real high octane cocktail doesn't it?
All The Best,
pese
Walter Hofmann
Hi all,
today was the day where I neede to go to the gasstation, I f you remember I used 10 pills of naphthalene mouthballs on 20 gal in my van 6 cyl 4.3l. without the mouthballs I did get 231 meiles on 20 gal. Today I pumped 19.8 gal in and the total milage driven with the filling and the 10 pills of naphthalene mouthballs was 319 miles I did get also 88 miles more out of the tank filling what is about 30 %.
This result is amazing I will only use this combination inthe future. The additional features was higher idlle speed and much quieter run of the engine.
greetings
walt
