Crystal Cell Research
Started by plengo, October 29, 2012, 06:08:15 PM
plengo
Quote from: drodenbe on September 28, 2014, 03:02:10 PM
Fausto:   Here is the latest.  I changed the line stile and shut off the pointing style to clear up the line to see what is going on.  Also hooked up my first cell before this one to a 100 ohm load and it is around .960 volts.  I will let this one run and see how it does.  I have the same mix in the cell but different style of plates.  Did you watch the video yet.  I would like to here your comments on what he is doing.  This is where I got my info on these new cells.
David
David I have seen that video and ALL his videos. Very impressive his work. Actually it is because HIS work I really got involved in this cell research.
Many of his graphs and explanations go very inline with my findings except with the thermo tests because I don't have means to use a calorimeter.
For example, the cell has its self-charging which does not pass a limit and therefore indeed works are a current source and not as a voltage source. With many resistor values the response IS DIFFERENT in a not similar manner, in other words, voltage does not become linear as expected to the ration of resistance but the current.
THe voltage shooting high really fast also happens with my cells when adding water at different times and then the cell stabilizes really quick which is very interesting his explanation why (matrix of diapoles aligning at the same time creating an adding effect of voltage - mini batteries in series inside).
Cell does fluctuate in power with time but constantly same average even though it is a constant source of power.
There are many other similarities with his graphs and my finding but I don't remember all now.
Fausto.
plengo
@David,
I am curious, what is the dimensions of your cell and weight? Can you share a picture of it?
Fausto.
4Tesla
Quote from: drodenbe on September 28, 2014, 10:47:55 AM
I am posting this link again.  I didn't receive any comments about it.  This is where I got most of my ideas on this latest cell.  I think he has some important ideas!
https://www.youtube.com/watch?v=u7y8ek9aASQ
David
Thanks David!
I've been to Marcus' website, but never seen the video.. I watched part 3 and in there he talks about how he would like to try different silicates.. then he says that he uses a group that has 150.. after googling I found that group is Zeolite!!
Some zeolites we already know, but some I didn't.  Here is a list of some of the zeolites that look promising!
quartz, calcite, scolecite, clinoptilolite, pryrite, thenardite (sodium sulfate), halite (rock salt), and erionite.  There are 40 natural zeolites!
I bet Marcus uses one or more of these that I listed above.
4Tesla
Okay.. I've compiled a list of about 130 Zeolites.  I bold the ones I thought looked good.. anyone want to go through the list and mark any others that might be good?
drodenbe
Hi again:  here is the latest results of the cell across 100 ohm load.
Thanks 4tesla for your research and info.  I will look at it.  When I saw his 2nd video I started to research some of his papers and found some where on the net a paper he wrote where he stated he used the sodium meta silicate.  This was an older paper so I am sure he has refined the formula since it was written.  But I thought it was a major find and that is why I built this cell using that compound.  It looks like it has paid off.  Not sure now if the pentahydrate part of it is a plus or not.  I saw that in the msds sheet I looked up after the fact.  It wasn't stated that way on the package.  It just said sodium meta silicate.  Maybe it is a plus because it was stated that it has some corrosion benefits. That is defiantly a benefit!
Fausto:  I don't have a camera yet but I will next month.  Will maybe try my hand at Hollywood productions as you do. But I will as soon as I am through with this post cad cam up a drawing.  Been meaning to do so anyway!  I will post it in a little while.  Thanks for your input as well as all the others.  I am going to make another cell after I post the drawing.  I am pleased with the results as you will see with the latest graph.  At least I think it is good.  You may look at it and say.....oh my I think it is dying by my experience!  So your input will be greatly appreciated.  May not make the second cell.  Depends on your response.  Thanks again.
David
