Single circuits generate nuclear reactions
Started by Tesla_2006, July 31, 2006, 08:15:00 PM
aleks
Quote from: UncleFester on May 18, 2008, 12:36:45 PMHowever if I load the windings heavily, the voltage does not drop!!! Very Strange!
Imagine a water fluid stream in a vertical pipe (e.g. waterfall under gravity force). Now start adding turbines inside the pipe. With 1 turbine you have X watts, with 2 turbines you have X*2 watts, without any power degradation since gravity force is constant and the water is not removed from the pipe - it simply falls down after rotating turbine. So, you may add as many turbines as height allows, without average turbine voltage change (the voltage will be roughly constant on each turbine's output)
Yucca
Use 1/8" aluminum. I'm not seeing any beta beyond the aluminum plate and I have seen some wild reactions while running continuously.
P.S.
Don't need tungsten (already tested)
Don't need a coil for B-field, use any magnetic source (already tested)
Don't need a toroidal transformer (tested multiple times with coils wound on any pipe or plastic form, same power with those as toroid)
Appears as though you dont even need any type of arc (tested good and running more tests)
Whatever you input frequency, will be your output frequency. (tested for many hours)
Looping output from toroid to input can be dangerous (runs away - tested two times and stopped)
Don't run without shielding (I ran a few times without shield and had a camera and calculator fried, they were sitting 1.5 feet away) (geiger did not measure dangerous levels though)
B-field strength and input voltage and current determine output voltage and current. The higher the b-field, the more current, the higher the capacitance on input, the higher the current and voltage on output. Tested over and over for many hours. It all appears to be interrelated and needs adjustment to make useful mains power. Other than that the sine wave off the toroid is very clean and stable, even nicer than mains power, no glitches, spikes or anything. Getting a stable 158VAC @ 60Hz on toroid windings but very little current due to not being able to capture as much beta as is available from the reaction. However if I load the windings heavily, the voltage does not drop!!! Very Strange!
More to come.....
Hi UncleFester (Tad)
This sounds fantastic! Please post a pic or a little more text detail on a working setup.
sulake
1. Appears as though you dont even need any type of arc (tested good and running more tests)
2. Whatever you input frequency, will be your output frequency. (tested for many hours)
3. However if I load the windings heavily, the voltage does not drop!!! Very Strange!
1. I have also been messing around with this setup now and I have not noticed any chance in the pulse energy with or without B-field. I have now only tried a setup where the thoriated tungsten rod is tightly attached to the carbon rod so that there is no spark at all. I drilled a hole to the end of the rod where the Th/W electrode fits tightly.
UncleFester, have you tried to run your setup by adding a wire in the place of the rods, so that you can tell the difference, how much is the excess energy? You can pulse a transformer with just capacitors and it works but there is no excess energy, of course not.
2. I agree and belive this. Transformer (toroidal etc.) does not chance the frequency. How could it? Except in some weird resonance state…
3. Well this is strange. Although, a transformers output voltage stays near the same all the way to the point where the core gets fully saturated and can not deliver anymore power. Electricians then say that the transformer is “crawling” (freely translated term). So how much power are you taking out, 300W…500W? What is the maximum output power of your transformer?
If you are discharging caps on a high frequency then your power source must give out quite a lot of amps? In my system the power source gives about 2A so the recharging time is much longer than the extracting pulse time through near 0ohm Th/W and carbon rod…
My setup stuff,  :)
epwpixieq-1
Has anyone try to contact Tesla_2006 about the technology ?
I did. The response, with a pdf document in English, was quite vague and seemed like the person(s) wanted to sell a technology more than to help develop something. It was mentioned that they already sold an device in Germany ...  Wanting to sell a technology that will help eventually everyone and earth,  is good thing, but when I request some info in order to be able to try to validate the technology ( if a real one ) there was no subsequent response  :-\  It seems like whoever is initiating this prefers to play a very non intuitive game. It sounds interesting and plausible but from theory to a working technology there is a HUGE difference named REALITY and very very few inventors were able to breach this gap.
SAS
Feynman
Hello gentlemen.
Parts:
Carbon Rod
Permanent Magnets
HV power supply (100-300volts)
Collector (does not have to be toroid, can be inductor).
Hints:
Use permanent magnets for your colinear B-field bias.
No thoriated tungsten!
No spark gap.
Be extremely careful.  God be with you.
-Feynman
PS  use aluminum shielding
