Single circuits generate nuclear reactions
Started by Tesla_2006, July 31, 2006, 08:15:00 PM
0 Members and 18 Guests are viewing this topic.
sparks
  @Fenyman and anybody who thinks life is worth living and bettering
Plazma is created from gas when the gas is electrically highly stressed.  Like in a spark gap.  You can proove this but you need experience with high voltage dc pulsed fields, a spark gap, and a thermometer.  A spark gap gets colder than the surrounding energy fields.  Plazma acts like a liquid and is responsible for all magnetic flow circuits.  It becomes relative to the entire tempic construct of the Universe.  Energy will flow towards the dc pulsed torroid in Alecks diagram.  The capacitors collect the energy and pulse the plazma creator torroid in such a manner that the energy flow creates a hurricane of energy conversion..   Study the Sun.  The suns surface is hot but the real energy we feel everyday is on the way towards the plazma cirulation inside the sun.  Now if you want to create a new sun here on earth Alecks diagram is the way to go.  Even SM knew enough to keep the control windings inside the plasmic ring.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Feynman
@Zerotensor
Great find
QuoteTo extract energy from Beta particles it is not just enough to capture them. Clearly this will result in a current flow according to the capture rate, but current by itself is not power. The kinetic energy of the particle must be captured and this will result in potential difference or voltage. If a Beta particle enters a thin foil conductor normal to its surface and is captured, then the potential difference associated with giving up its kinetic energy can be expected to occur across the opposite faces of the foil. If however the Beta particle were turned so as to enter at a shallow grazing angle to the surface, not only would the probability of capture be increased (since the particle will travel further within the material) but the potential difference will occur along the length of the foil. Beta particles travelling even at relavistic velocities can be turned within short distances by relatively weak magnetic fields, so the concept shown in the following Figure suggests itself.
I wonder if aluminum foil will work, and also maybe it should include a thin insulator which does not block beta?  OR perhaps just use air as the gap and somehow give it structure through some cardboard shunts.
Feynman
@Zerotensor
Actually wait what happens if you get the spiral direction wrong.. hmmmm... ::) ::)   It might not matter, right?  Because inside will have the highest net (-) charge and outside will have highest net (+) charge?  Theoretically, you can pull a DC current equivilent to the number of rays you are producing?  I'm starting to think this just might work!
wavez
Here are pics of what I made today:
It's really crude, but if it works, then I'll make something a lot nicer.
I guess the aluminum shielding is not suited for capturing the output. I'll make a coil with the wire I have and maybe get some of that ribbon wire ordered.
waterfireho
Here is some more info....  I'm still diggin haven't got to Emails yet.
Random Notes.....
The main purpose is design a circuit for discharge a condensers bank for tap energy in the nuclear reaction performed in a pure carbon rod with the following dimensions:
Length = 60 millimeters
Diameter =  6 millimeters
Then, the volume of the carbon rod will be  1,7 cm3, value for consideration in the required energy level for the initial nuclear activation process inside of the carbon rod, at more volume more starting activation energy and more energy at the output , this is because the carbon rod used for you can be of different dimensions and may be no a pure carbon rod, if the rod is not pure the calculations can be approached as if it was pure, is best use an excess of energy than use a value down the minimal starting required
Resistance of the carbon rod = 0,18 Ohms
Voltage of the condenser bank used = 37 Volts DC
  And so, we can see a peak of current in the condenser discharge of a maximal current of 37 / 0,18 =  206 Amperes , value for consideration in the choice of the power Fet can support that short pulses of current, the true value of the discharge current peak will be more because the parallel resistance added for the electrode reduce the initial resistance of the carbon rod
  For get the energy of the beta radiation o or high energy electrons I use a toroid wired of the following way
Diameter = 6 mm
Number of turns = 300 , with wire of 0,5 mm of diameter
Polarization magnetic field =  135 gauss
  The volume of the carbon rod establishes the minimal energy for starting the nuclear reaction , value we can calculate, as I was a DC power source of 37 Volts that is the stating charging voltage of the condensers bank and the total capacity as before mentioned is 160000 microfarads
  The condensers bank I was using don?t was electrolytic, I use Mylar condensers, 2 condensers of 80000 micro Farads each,
I suggest not use electrolytics, each condenser support until 50 V DC each, however we can work with others voltages and others capacity values, the formula for the energy stored in a condenser is
         U =  ? .C.V?
  Where C is the capacity in Farads and V the load voltage , then we can see the more influence variable is the voltage V,
that is say if we double the voltage the capacity for get a certain energy level will reduce 4 times, or if we use 10 times the initial voltage the capacity will reduce 100 times, and so if we use high voltage  the capacity will reduce notably , the limit is in the voltage can drive the power transistor used , for that reason Tesla was using vacuum tubes because it support high voltages,  and can be used as condensers or transistors, in this case we must keep the following proportion:
      C.V? = 0.16 .37? = 219.04
That is say, the energy stored in this condensers bank is about 109 Joules, and in the following we can see a table for voltage in load and capacity of the condenser bank and you can choice the best option according your resources
Case   Capacity (micro farad)         Voltage ( Volts )
1   1521200                                12
2   380300                                 24
3   87620                                  50
4   21920                                 100
5   9740                                  150
6   2280                                  311
7   760                                   540
For the case 5 is like connect a condensers bank to an electrical net of 110 VAC, the case 6 is for a net of 220 VAC, and the case 7 for the voltage between the lines or phases in a triphase system of 220 VAC for phase and 380 VAC between the lines
The discharge to the carbon rod without polarization in the toroid get the nuclear reaction in the internal structure of the rod, but as there is not alignment of the magnetic dipoles inside of the rod there is not a coherence in the electrons emissions for sum electrons to the electrical current in the carbon rod and there is not the necessary acceleration of the electrons inside of the carbon rod like the cathodic rays in a TV monitor , remember electrons inside of a conductor moves too slow and here we need a big speed added for the capacitor bank discharge and the polarization magnetic field of the toroid get an acceleration effect
   Testings and meditions shown here are for a first cycle of starting of the device, the closed loop operation is obvious, but here is not shown because is not practical, you will have a setup not equal to the used here, for that reason is than you build his discharge setup and get his parameters measurements for get the best values of feedback timings and the feedback power
The device is portable because one time is required for the start of the system and since the system is precharged it is portable and can start in any place and weather condition and any transportation conditions
For finish, we can use not only solid plasma, discharges in gas tubes get the same results without magnetic polarization because there is a return of power to the initial starting discharge condensers bank, neon tubes is an option
Will add more later as I find it.
Dave
