Single circuits generate nuclear reactions
Started by Tesla_2006, July 31, 2006, 08:15:00 PM
waterfireho
Quote from: Inventor81 on May 22, 2008, 07:36:39 PM
Further, the unit would definitely dissipate 60KW worth of beta into the air or the device itself, eventually turning into heat.
Apparently I have miss understood something here....
Isn't the Beta supposed to be converted to electricity in the Copper wire of the torrid. ????
If it is dissipated as heat then the wrong conversion of energy took place ? no.
UncleFester
Self running...
didn't happen.
It did not charge the battery.
Lol! Keep up the theories man. I get a kick every time you post hahahahaha! Since you've figure this out without any experimentation you should probably go work on the particle accelerator with your PHD friend. = )
In the meantime I'll keep plugging away and watching my scope = )
wavez
@UncleFester
Maybe I've missed it somewhere, because I'm still wondering exactly what your device looks like. Can you give us some comprehensive documentation? Pictures would be great, along with diagrams and all the parts labeled with enough info that someone can reproduce the machine you have there.
UncleFester
Quote from: wavez on May 22, 2008, 10:08:44 PM
@UncleFester
I just stopped for dinner, but about to get back to work. Pictures I can do soon once I get my new camera here (mini-dv). Documentation other than what I have posted already I cannot do, it would take forever and I don't have the time before I end up going back to work at the local coal fired power plant. Third, the device I have IS NOT in accordance with what Juan (person who started this post) had documented. My whole job here is to duplicate what he did and see if it works as he said....nothing more.
If it does end up working as Juan stated then I will post everything I did, although it will be identical or as close to Juan's machine as I could get. So everyone will have just as much information on it at that point as I will.
zerotensor
Quote from: UncleFester on May 22, 2008, 10:17:47 PM
TJ-
Even if it doesn't work, I hope you will share with us what you did in some detail -- Please don't pull a "David Bowling" act, leaving us hanging without any salient information.  Negative results are still results!
Also, what seems to have gotten you (and us) so excited is the first setup, which behaved in a dramatic and unexpected way.  Just because it's different from Juan's machine doesn't mean it's not worth sharing.
Don't let confirmation bias prevail!  Please report your methods and results -- good, bad, or ugly.
<edit>  ps is that neon transformer the same one from the Moray experiments?  ;)
