Single circuits generate nuclear reactions
Started by Tesla_2006, July 31, 2006, 08:15:00 PM
forest
Is carbon rod heated during these experiments ? Maybe we should ask why carbon rod can generate light when treated with high current ? Is that explained ? What if beta is somehow converted to light and heat and then how is it going ?
pese
D13..
This is another history.
That is an nuclear battery (1KW) to use in satelitte systems.
that develot from an radioant probe that must be radioate wit an small 300Mhz Transmitter
(only a few watts) so that "nuclear device" delevop approx 1KW.
that is ann english patent from 50 years away...
Pese
Quote from: AbbaRue on August 22, 2008, 02:03:24 PM
I found the following subject on this forum closely related to what we are trying to achieve here:
http://www.overunity.com/index.php/topic,2827.msg122875/topicseen.html#msg122875
The patent they are speaking of can be found here:
http://free-energy-info.co.uk/PatD13.pdf
Download the patent info and perhaps it's principles can be applied to the carbon rod.
Maybe we should be grinding the carbon rods into powder and making a similar unit.
We just need to find the right frequency for carbon.
Unless 300MHz will work for carbon as well.
mikewatson
Quote from: forest on August 31, 2008, 10:26:50 AM
Yes, I use a touching contact between two carbons or the carbon tungsten which flashes light when the capacitors discharge through it so presumably the temperature is around the usual 3000-4000 degrees. I got nothing from a solid carbon rod which was suggested by the originator of this thread.
C. L Kervran described possible low energy transmutation in biological systems which do not release radioactive particles, if so it is probable that an extra electron current is generated instead of beta particles at the carbon junction.
Mike
mikewatson
Quote from: ramset on August 30, 2008, 04:50:35 PM
Mike Watson It was Uncle fester
Have you heard from Feynman ?
   Chet
Thanks, no I have not heard from either of these gentlemen, presumably either they have got something working and gone quiet or they have just lost interest.
Mike
mikewatson
   Chet
Mike
