The Paradox Engine
Started by Tusk, November 16, 2012, 08:20:52 AM
Tusk
Your mechanical rectifier appears to be both well engineered and a fine idea webby1.
I made several attempts at designing a simple apparatus based on PE principles which employs exclusively mechanical methods to achieve a self running system, but generally I discard any design beyond my own laughable amateur engineering abilities before it even gets from pen to paper. Unfortunately the basic idea while simple, does require the redirection and integration of two independent motions to achieve success. I'll give more thought to that and get back to you if a promising design offers itself up.
Your idea of measuring the output from the main rotor arm has merit. There is still the matter of disk output, although there are different ways of cycling the device and potentially all output might be directed through the rotor arm. Again I'll give it more thought, with thanks for your contribution - this is all very encouraging  :)
telecom
Quote from: Tusk on December 27, 2013, 06:53:47 PM
What is disturbing to me in the present design is the fact that everything runs from the battery which is not connected to any wires for charging. May be instead of a battery to use some kind of a sliding contacts to power EM drive from the main?
This way it will be possible to implement the power recovery during the stopping of both the disk and a rotating arm.
Tusk
I'll reply to your comments first webby1:
QuoteMy thought of using only the arm is that the disc should be a freeby,, that is you pulse the input to accelerate and then you take that back out to decelerate, and these two components move the arm in opposite directions,, so you spin up for the arm moving say 1\4 turn and you spin down for the arm moving 1\4 turn the other way.
Hmmmm. Currently there is no regenerative braking on the drive unit (although it does provide simple EM braking) so that with your idea in place we would still not be getting anything back from the disk rotation (other than the secondary motions of the rotor arm). We could allow (quite rightly I believe) that each braking period has a theoretical return of 100% of the energy supplied to it (during the acceleration period) but if that is acceptable, I wonder why it is apparently not clear to anyone that any energy reclaimed from rotor arm motion takes us into OU.
I like that you have gone with the cyclic nature of the device btw; the universe is supposed to be asymmetric (and appears to be so) therefore a cyclic method of extracting energy somehow seems appropriate. I need to feed each new idea into the alarmingly convoluted spaghetti programming which constitutes the sum of my knowledge, so please forgive any hesitancy on my part  :)
also this, from telecom:
QuoteMay be instead of a battery to use some kind of a sliding contacts to power EM drive from the main?
Beyond my build capability telecom. It pays to know your own limitations... and I get electric shocks from clockwork toys, not to mention blowing up nearly every power supply I own (usually due to incorrect polarity)  ;D The fact that the current battery powered apparatus still runs is testimony to my self control, having resisted the temptation to modify it since rewinding the coils.
What if you could tweak the concept a bit, use some electromagnetic paradoxes to achieve an ever increasing rotation speed with a constant electric input. It stems from the homopolar field where a rotation magnet/solenoid exhibits the same effect as if it were stationary. This way you solenoid being torqued, will increase its speed due to the torque without it having any detrimental effect on applied electric power.
Here's a short animation of what I'm talking about:
http://www.youtube.com/watch?v=umN-6fa5ZEs
refer to the video description for explanation.
Until you realize the Freudian whiplash.
