kapacitiv Transformer
Started by sergirafael, November 21, 2012, 05:37:47 PM
Neo-X
tinman
Quote from: Neo-X on January 15, 2013, 10:43:37 PM
Nosebleed...  :'(
Indeed
Would there be a schematic for the compleete setup?
Neo-X
@all
Is it possible to make a transformer made up of only capacitor?
Neo-X
I made a experiment just to confirm my theory but the result was failed.. :(
I was thinking that if i wound a coil in any condutor like spoon then connect it to the ac voltage source, the output voltage in the coil is much higher to the input. But the result the voltage is the same.
sergirafael
The coil is then wound around the capacitor plates. the coils
Now you can switch parallel with the capacitor plates. the resonance circuit
can be excited by a second coil winding. the zeweipol
can be switched via a diode to a load. Is an important
To obtain threshold not make the whole pathogen energy
Together Torn is.
The capacitive transformer as a resonance circuit
  constructed in a different way. The green and red Alluminiumfolien
are wound about each other. Lying between the is an electrolyte.
It can also be more than just two were superimposed Alluminiumfolie
be wrapped. The green plates verebunden miteineander
and the red plates are interconnected.
The result is a capacity. *
A resonant circuit which can supplement the electric and magnetic alternating field lines can also be constructed as shown in the drawing. The electro-mechanical component of the capacitive voltage to the attraction between the capacitor plates and the drifting apart of the magnetic force of the coil can be the component in response to loud. In resonance, a doubling of voltage to be measured, at Jeem resonance circuit. The change of the magnetic flux gets a change in the electrical field HERFOR, where in the drawing an erroneous idea. I did not take into account that the field lines are shifted 90 ° Spatially.
