Lynx Joule Inverter
Started by Lynxsteam, November 29, 2012, 12:42:40 PM
PARAV
Quote from: totoalas on December 24, 2012, 04:20:55 AM
Hi
Yed its the same tate ckt
Hi Totoalas,
Thanx. for the quick reply--Paul
synchro1
@ Totoalas,
               Can you place a multimeter between the antenna attached to the A.C. neutral and the ground to see what the D.C. voltage reads from the APM?
totoalas
The meter reads 210 v dc max in the 500 v dv scale without load
With 3w 220v ac led load the lamp is dimly lit with 106 v resding at the same time
With 4th generation 3w led lamp it fladhed and and the v reading  goes up after discharge
With or without the circuit dame effect with the lamps
Neutral as antenna and ground connevted to earth
forest
Excuse my stupid question about circuit from LED lamp , posted on page 2. On input just before diode bridge there is 15R 3W resistor. Isn't that interesting ? Bulb is rated as 3W output and here we have current limiting resistor I suppose , also rate at 3W ?
I wonder if anybody ever thought about replacing this resistor wit the same one on long wires and measure carefully the heat radiated from it during led operation ?
synchro1
@Totoalas,
              Wow! That's so fantastic! My sailboat APM generated only around 1.5 volts D.C. with the 22 foot aluminum mast antenna and the iron keel ground. 210 volts is plenty to charge a 120 volt battery regulator.
               I think it would help to marry a Lynx Joule Inverter 220 volt 1:1  transformer to the APM to run the 3 watt 120 volt A.C. LED. I believe we can run the entire economy off this system. Awesome!
