Question about magnetic induction
Started by tsl, November 30, 2012, 09:53:34 AM
tsl
@TechStuf @Neo-X
hmm, let's see, know what? amuse me, do a case study.
and when you're done( or if ever) be assured that a discussion about radial magnetic field anomalies
would habe been actualy interesting but of course not here on this forum for OU professionals.My bad
God bless you
Liberty
Quote from: tsl on November 30, 2012, 09:53:34 AM
hello @all,
take a look at the picture attached
M1,M2 are permanent magnets or coils that generate a static constant field
C1,C2 are coils that are creating opposing fields
L is a simple loop
Question :
If M1M2 field is constant and the field generated by C1 and C2 is abruptly switched off (or on) will there be a current induced in loop L?
I say there will be one, what are you saying?
:-X
Since we don't know the distance of travel of the magnetic fields surrounding L1, the only reasonable answer would be:  If there is a change in magnetic field strength at L1, then L1 will realize a pulse in proportion to that change in magnetic field strength.
Liberty
TechStuf
Quotebe assured that a discussion about radial magnetic field anomalieswould habe been actualy interesting but of course not here on this forum for OU professionals.My badGod bless you
Neo and I were just checking your skin condition.  Now as to those "radial magnetic field anomalies", I am interested as to just what you've observed.  Personally, I'd be more interested in any "linear magnetic field anomalies" you may have encountered.
In our endeavours, it's always good to remember that "hands on" beats a "hand out" hands down.
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
Bruce_TPU
hello @all,
L is a simple loop
Question :
:-X
Hi tek,
Good question, but the answer is no or very LITTLE induction.  Been there done that, with slightly different setups.  Even if magnetic fields are switched on and off, if there are opposing fields, you get zip, nada, nil, neign.  Sorry.
Cheers,
Bruce
Quote from: Liberty on November 30, 2012, 12:11:25 PM
_Rate_ of change.
