Karl Schappeller's Secret Sublimate for his Electret!
Started by gravityblock, December 05, 2012, 12:52:18 PM
gravityblock
Below are a few quotes from the Physics of the Primary State of Matter on Schappeller's secret electret sublimate.
Quote from: PPThe sublimate must be charged with electric current, after which, provided no power is taken from it, it will retain its charge as we saw in the case of the Electret; the Sublimate in this case is an energy sublimate (produced by the new plant referred to above), but this sublimate is bound to a composition of substances in the solid form with which the tubular coils are tightly filled.
The charging plant required is merely that necessary to give the required number of amperes, the plant being composed of the requisite generators and units, according to whether the grid current is available or an entirely different supply is required, or both as a "standby". Such plants will, of course, supply direct current.
Quote from: PPThe main cost of demonstrating the application to mechanical power lies in the purchase of the charging plants and standby sets, which latter are absolutely necessary for certain reasons, and also Schappeller's special plant for the production of the initial sublimate by occasioning transpiration, followed by condensation and sublimation, all in the energy form.
Let it therefore be clearly understood that any suggestion of small laboratory models or the like is out of the question or they would obviously have been used and the application of the Primary Force to mechanical power would long since have been tested out. The transpiration could not be produced by models and the essential sublimate could not therefore be produced except by a plant of certain minimum dimensions capable of producing transpiration, and this also applies to the Stator and Rotor which is obvious here when the design of the Stator is carefully examined.
There are three things I want to draw your attention to in which is part of the sublimate/electret process:
1) Transpiration is a process similar to evaporation and it occurs in plants.
2) Condensation is the change in the phase of matter from the gaseous phase (of an element/ chemical species) into liquid droplets or solid grains of the same element/ chemical species.
3) Sublimation is the transition of a substance from the solid phase to the gas phase without passing through an intermediate liquid phase.
IMO, the above three things are very similar to the process of creating aerogels. Aerogel is a manufactured material with the lowest bulk density of any known porous solid. It is derived from a gel in which the liquid component of the gel has been replaced with a gas. Aerogels are produced by extracting the liquid component of a gel through supercritical drying. This allows the liquid to be slowly drawn off without causing the solid matrix in the gel to collapse from capillary action, as would happen with conventional evaporation.
In Schappeller's lifetime, the creation of aerogels could only be done in the most sophisticated laboratories, thus the reason for this statement being found in the PP document, "small laboratory models or the like is out of the question".  Prof. Dr. Halimaton Hamdan, of the Dept of Chemistry at Universiti Teknologi Malaysia has patented a method of creating aerogel from rice husks at a fraction of the normal cost, and is known as Maerogel. Take note how the rice husk is burned on a heating plate at a temperature in the range of 650° C. to 700° C. with excess air until a white ash is obtained. Combustion at 700° C. produces the most reactive silica source which predominantly contains pure amorphous.  Aerogels were discovered in 1931, so Schappeller was more than likely aware of this discovery. 81 years later and we still aren't capable of getting the aerogels to the market with any kind of efficiency or at a reasonable cost, LOL.
Below is a quote from Professor Halimaton Hamdan in regards to (m)aerogels from rice husk in her publication on Nanomaterials as catalysts in the production of fine chemicals found on Page 3.
Quote from: Hamdan
Silica aerogel is a potential substitute for silicon dioxide, the reigning dielectric. Silica aerogel offers a better way to keep the interconnecting wires from shorting across the narrow dividing space between transistors which avoid propagation delays and excessive crosstalk and subsequently may double computer speeds.
Maerogel; a silica aerogel which is directly prepared from rice husk (Figure 4) is a nanomaterial of a highly divided state and exhibits unconventional properties which offers more cost effective methods of production and application. Maerogel is more superior in quality than the current commercial TEOS aerogel.
A dielectric is an electrical insulator that may be polarized by an applied electric field. When a dielectric is placed in an electric field, electric charges do not flow through the material, as in a conductor, but only slightly shift from their average equilibrium positions causing dielectric polarization. Because of dielectric polarization, positive charges are displaced toward the field and negative charges shift in the opposite direction. This creates an internal electric field that partly compensates the external field inside the dielectric.
An Electret is a dielectric material that has a quasi-permanent electric charge or dipole polarisation. An electret generates internal and external electric fields, and is the electrostatic equivalent of a permanent magnet.
The maerogel is more superior in quality than the current commercial TEOS aerogel and has a potential to replace the reigning dielectric of silicon dioxide, in order to form one of the best electrets possible.  Maerogels may be able to reduce the cost by 80% as compared to other manufactured aerogels.
Here's a quote from page 126 of the PP document in reference to the initial stages in the formation of the earth's crust, which directly refers to the creation of a silica aerogel.
Quote from: PP
The marine life entered into the gaseous or vapour state, drawing or sucking in the carbon-static. The death of these vast organisms brought the peripheral film to the plastic or gel state; on becoming a solid having stable Space-form, it became virtually silica (this is describing a silica aerogel), and permutations of this in rock form were derivatives. Silica, being converted carbon, oxidised, the oxygen being present in abundance as the complementary stressfield.
In summary, silica aerogel is Schappeller's secret sublimate for his electret.  Schappeller needed a very strong electret for his prime mover, shown below, and the silica aerogels is the best solution and is a perfect match for what is described in the PP document. Here's a video showing a derivative of the silica maerogel in rock form, as described in the above quote, which used evaporation without the use of super critical drying.  Rice husks could be hard to obtain.  However, silica isn't limited to rice husks, as shown below.
Reference Link: Mindat Mineralogy Messageboard
"silica is deposited in the plants as amorphous, Opaline silica."
"Nettle and tobacco , for example, are rich by silica.
Some gem cutters use tobacco ashes as polishing reagent"
[Edit:] The red text inside the quote is my own comment and does not appear in the PP document.
Gravock
ourbobby
Quote from: gravityblock on December 05, 2012, 12:52:18 PM
Gravock
I think what you are trying to say is that the electret process was "Sol-Gel"?
But then he "only" used the so called piezo-/pyro-(transducer)phenomen ?
Sincerely
            OCWL
conradelektro
I looked a bit at German and English material about Schappeller. This is Theosophie (Esoteric) and has nothing to do with any identifyable technology. It is hardly possible to find more than a huge "globe" as far as any technical specification goes.
If you can read German, look at this http://principality-of-sealand.eu/vril/Raumkraft_print.pdf . In short, it is just esoteric gibberish and leans towards Nazi lore.
"Put your hand on the sick persons knee and then say two short prayers and the person will lift of the ground. The person will only lift if she/he is of Arian stock." If you understand what I mean by esoteric gibberish and Nazi lore.
Can't you find some other amusement?
Greetings, Conrad
e2matrix
Mostly to play with the new OCR program I translated this to English.  Attached is doc conradelctro put up - now in English.
