HV Electrostatic Convert to Power
Started by enSync, December 07, 2012, 09:32:42 PM
enSync
I have developed a device that converts Electrostatics Energy into Continuous Actual Power.
It is for now low power and could be made into much higher power.
At this stage all it is good for is a demonstration that it can be done.
The output is enough to power/charge an electronics device.
It would require much attention in advanced research.
It 'exhibits' over unity absolutely with a simulated input (Electrostatic).
I cannot connect the input to the output yet...it could be in time
with further development and research. It is possible to make it a true
over unity device. But not by me as I have no advanced lab or money for
continued development/R&D.
My problem now is to patent it.
And its a big problem because a discovery like this
would be infringed upon by other countries, let alone the USA.
So here I am with a cool device and no money to pursue a course of action.
The DOE says it will not validate it because it would be a conflict of interest
with the Government.
Peace,
enSync
gauschor
What are the options? You said it yourself, it will not validate due to government interests. Your choice is either to keep the secret or give the secret all mankind. How about a small video demonstrating your device?
enSync
I think all people that invent something like this will have this problem
that are without money, etc.
I have to increase the power output a little more as the device that could
now be powered is only ultra low powered silicon based micro-chips,
some not even out in the market yet.
I think I can increase it enough to power a mini-fan or 10ma LED at 1/2 power.
Once I do that soon I may buy a video cam and at least show it can be done.
Since it is not true over unity it has little use except like I say a demonstration.
Makes a Great Toy! :o
enSync
'I am at the door that is unlocked and never opened'
conradelektro
A very sad story, I can nor stop weeping.
Consider this: Making money will be a simple task in comparison to making your device OU.
So, you make money and then you do whatever you like.
Chances are, once you have money you will not need OU any more and most importantly you will be able to stop whining.
It has be proven beyond doubt, that whining impedes OU.
Greetings, Conrad
mscoffman
You should go ahead and show the device, at least to yourself,
in a self-powered loop. There are already ways of converting
large amount electrostatic electric energy into standard electrical
current. For example use the electrostatic energy to light a CFL
tube in the presence of a solar cell battery. The real question is;
Is static electricity, the technical term is; triboelectric energy,
generated via an overunity process?
The self powering loop would answer that question for you. My feeling
is that it is: It is a macroscopic evidentiary form of the beta nuclear
force in operation.
The fundamental though question is; What are the negative ramifications
of utilizing an environmental degrading operation especially if thousands
of consumers try to use it simultaneously at very nearly the same location?
I think you will find generating energy through using electrostatic energy
has such negative ramifications.
:S:MarkSCoffman
