TK device, TPU.. Only enter if you seek truth. Cause here it is...
Started by elementSix, December 14, 2012, 07:26:31 PM
verpies
elementSix
RUSLanX and Dimitry from real strannikk russian forum and their work on the TK style coil setup.  It's very over my head, but what isin't.  This setup is  so strange but I thought it should be posted here anyways.  Its on 5KW forum also..
Ruslan and Dmitry ustanovka THEORY CE DMITRY A lot of discussion about how to make a generator providing power to a greater extent than it needs to maintain its operation. In another generator "free energy." To make it you need to understand the process and what exactly to do, what to achieve. Energy that you want to just take it is impossible, but it can provoke a response that will allow this action and use. Energy is all around us, but it is also the basis of any material object. It only reacts sharply to the action of its kind in its purest form. Any material object transforms it from a monolith in smoky, the objects in the form of a pyramid or funnel twists it into a spiral. Some physical processes also affect it, and it becomes a carrier of these phenomena. Many manifestations are known to you. For example, the forces generated under braking and acceleration, the electric current and magnetic field.
Because we want to make a device that allows us to provide energy to a greater extent than the energy expended, this is the simplest to use conductors and their properties. Imagine a pipe large quantities, which is moving "something" and this "something" gets sand, the sand is our electrons - heavy material objects, and the flow of "something" - this is our energy. To release it, we need to get our separate tube, is a simple gap.
Velocity of the energy above matter, and the stronger the movement, the more sand is fond of this thread. In modern physics, this is called an electric current. Our energy of the conductor can come to the surface and affect the surrounding area only, provided in our pipeline, which moves the flow of energy and electrons, you create a thread, but its direction will be counter. The power of counter-flow, and will depend on the volume of our energy release through the gap, and thus the strength of our impact on the world. In physics it is called electrostatic bursts.
In essence, these two streams provoke rupture field confining the electrons in the energy and arrester. It's like an explosion, which can form in the environment Etched form, as if pressed a hand to the gel structure, and she immediately tried to return to its original form.
Are you familiar with a device called "crystal set" that can work due to the fact that the wave energy produces energy and displacement of electrons in a conductor (harmonic oscillations). In our case, the wave, as such, no. A provocation of space and the opposite effect, which is expressed in the form of impact on the conductor in which there is a shift of energy and electrons in a unidirectional vector, ie KICK-SHIFT-rebound. The beauty is that of shock and displacement is due to the energy contained in the conductor and the energy of the environment. But our task - to create a little counter-flow and the conditions under which these movements occur. And it is - just create a difference between the "potential" for small plates of the capacitor capacitance.
The frequency of the device is set to your source of stable high voltage spark gap and capacity. The problem is that the impact on the flow, moving from negative to positive field capacity, it is difficult, due to the fact that until the energy does not make any movement through the gap, there will be no work that we can использовать.Следовательно, the first stage of motion we are forced to miss. It remains for us to catch what udet move from the positive to the negative of capacity. Consequently, the wire connecting the negative and the surge tank should Met some length. It is usually in the form of rolled coil.
If you have questions, speak. We received a chain that is usually portrayed in textbooks (Transformer, rectifier, capacity, discharge from the positive element of the rectifier and inductor). After collecting this circuit we seem to have a large area and low-energy electrons, as well as the path consisting of the shock wave and spark coil.
All of you know that one handler, which is moving "something" is the movement in the other conductor, located nearby, but after a certain period of time. Therefore, to organize a quick interception, ie create a counter-flow you can not, because you are retarded in time. In essence, you have to catch that already flew past you. One way out of this situation: You have to use the original potential difference of your capacity to create another action, ie creating another "capacity." Create - this time, which we need. But our capacity will be provided in the form of coils having two bmotki (one on top of another). One side of the coil through the gap udet Connect to negative, and the other through the gap to plus. Second winding will have one way out, and it will be connected through the gap to plus or minus. Do you get inductive capacity with three terminals connected to a power surge through the potential difference. Now, your chain will look different. Reference point, then oprotivlenie (can a small coil with a small number of turns), then surge, then current, from which come the waves, then winding spiral that spins, then he should surge and impact.
Remember the magnets that like poles repel each other. This device allows you to temporarily increase capacity at some point. But this is not the only way. There are various options. Учтите, что при всех выше описанных действиях, энергия с отрицательной обкладки конденсатора еще не начала путь, т.к. мы получили работу за счет кратковременного "всасывания" электронов из нашей волновой катушки в сторону плюса емкости и блокирования их затем другой обмоткой. В итоге у нас есть выведенная из равновесия емкость, работа, которую мы сделали и которая позволит нам подготовиться к нашему главному действию. Мы должны будем создать поток, двигающийся на встречу другому потоку. Их разделяет наш разрядник.
You should already know that creating a thread (which will move towards another thread, who had previously passed this way and now seek to go back), and they met, could result from the movement of energy on two adjacent wires in one direction, which leads to returns. The stronger the "Twist", the more "toss." Therefore, our system of separation of the electron energy will consist of two parts. The first part described above. The second part of nearly the same as the first, in the action, which makes the first part of "folding" and "return").
You must find a way to organize the two counter flow. One will move from the "positive" and the other by the "negative." This will result in the field in the gap and the output energy to the surface. Since this effect is struggling in substations, he appears when turning the high-voltage circuit breakers. Once you have created two opposing flow, and their meeting took place in the spark gap, there was a burst of electrostatic (ekstratoki), this burst of energy to send to the coil with a big step and a small number of turns (usually use a thick copper bar (wave transmitting coil)) . Energy for inductive loads must be removed from the coil located on the same line with the wave. Also, due to the fact that in the system used in high-voltage inverter semiconductors, consider protecting them from strong static bursts. Suitable for these purposes "grounding" or battery.
Regards, Dmitry.
elementSix
So instead of semiconductors making the pulses, it's just the spark gaps?
elementSix
Here is a regularly updated link to a PDF from RusLanX, on his device workings and updated schematic..
http://www.fayloobmennik.net/files/go/50517084.html?check=02f82407fc8260a406651a746b573df6&file=2366188
This is the most resent Schematic..
