TK device, TPU.. Only enter if you seek truth. Cause here it is...
Started by elementSix, December 14, 2012, 07:26:31 PM
andrea76
something similar happens in the air around the conversion devices?(or as they are more know "fre energy devices)http://en.wikipedia.org/wiki/Redox
verpies
Quote from: elementSix on January 21, 2013, 11:30:59 PM
This is how I had the YOKE hooked up.
That picture is much more informative.
According to this the equivalent schematic of this setup is shown below.
The direction of the windings is denoted by the dots.
The new information is that the core is split and probably loose.  If the T1 winding directions are the same then the core halves will be attracted to each other, when any current flows through T1's windings. This attraction will create a slapping motion between the two core halves, which will create acoustic noise.
The section of the coaxial cable acts merely as a small capacitor (denoted as C3)
The circuit will be difficult to analyze because the mutual coupling of W1 and W1 of T1 is probably not 100%.
Also, the C1/C2 and W1/W2 of T1 form a frequency dependent LCR circuit, as well as C3 with W1 of T2.
Two interacting LCR cicuits and ferromagnetic effects (e.g. saturation, nonlinearity) would make the analysis very difficult.
I will not put more effort into analyzing this circuit unless it is measured that its O/I power ratio is greater than one.
IMO there is nothing unconventional about it.
This circuit is very different from Wesley's team Yoke device. Most importantly, the system lacks the perpendicular copper strip winding.
elementSix
I used 2 small electrolytic caps.  one is an Elite  680uF 200V, and the other is SamSung 470uF  200V
segar
HI, MUSTAFA,
in here i have do some drawing following by your circuits ,,,,but in here don't have battery,and the feed back circuits. as per-discussion you have write there some info for the input power and output power.
input power consuming low and output power consuming high, this is no susting can be delivery high output.
you can see from the my simulation circuits and drawing too, its showing that low voltage and same current after LOAD lamp.
i will post to you the file ,please look at did and let see.
in theatrically its not works, and also i have been tested the practically too, its same results is getting ,input and output power consumptions.
elementSix
I'm Going into another direction with The TK setup.  I don't think it operates the same way as the TPU..  I have been reading more on the Tesla Magnifying transmitter and I belive that is where its at.  Below are a few pages with a little info on them.  Let me know what ya think.  I think TK wraps coils with the secondary of the Transmitter inside the arrangement
http://www.scribd.com/doc/74052068/Tariel-Kapanadze-and-Tesla-Circuits.
http://tesla3.com/images/forum/Tesla%20Magnification%20Transformer.pdf
