TK device, TPU.. Only enter if you seek truth. Cause here it is...
Started by elementSix, December 14, 2012, 07:26:31 PM
elementSix
This is what Ceprea B, our Russian guy on the Forum says about the Red Device.
-> TRY RED SCHEMATIC AND YOU WILL NO REGRET. SECRET OF SHAMANADZE IS HERE !!
ALL OU GENERATORS USE ONLY ONE #1 PRINCIPE. DALLY USED THE SAME PRINCIPE. DISCOVERY BELONG TO ONLY ONE #1 NIKOLA TESLA. HE DID IT BEFOR 100 YEARS AGO BUT JEWISH BANKERS(ILLUMINATI CABAL) STOPPED HIM TO GIVE IT FREE TO WHOLE MANKIND. SO OUR DUTY IS TO CORRECT THIS TERRIBLE MISTAKE NOW. AND BANKERS CAN GO TO ANOTHER PLANET (IF PERMIT THEM ........ )TO DIG UP FOR OIL. AS STEVE P. SAID F....BANK...S
TO DLLABARRE
THIS IS RED TOPIC. WATCH VIDEOS !! COIL HAS 3 LAYERS WINDINGS - SIMPLE WINDINGS. YOU CAN TRY TESLA BIFILAR, CADUCEUS COIL, TRIFILAR OR ANY CONFIGURATION. MAYBE YOU GET MORE POWER THAN HE GOT. RED POWER BALANS IS MIN 2:1. ON INPUT 36V, 2.5A. HE WAS LIGHTEN 1KW LIGHT BULB AND 300W. USE THICK MONTAGE PVC CONDUCTOR 2mm-3mm IN DIAMETER. MAKE BAR FROM 10-15 STRONG Ne2Fe14B MAGNETS AND WIND 3 LAYERS OVER (or 4,5,6...). TRY MULLER COILS 3 STEPPED COILS, ALSO TRY DON SMITH COIL, WINDINGS FACE TO FACE IN OPPOSITE DIRECTIONS. CAPACITORS ARE ALL HV FROM MICROWAVE OVEN, DIODE COLUMN FROM КЦ201 RUSSIAN AVALANCHE DIODES. PUT THEM IN SERIES FOR VOLTAGE 25-30 KV. MAKE OWN EXPERIMENTS AND ANALIZE ALL WHAT YOU GOT. DON'T WAIT FINAL SCHEMATIC FROM ANYBODY !!
RED ADVICE. DON'T USE HIGH RESISTANCE (IMPEDANCE) LOAD. USE LOW RESISTANCE LOAD 2BULBS 300WATT IN PARALLEL !!
MY ADVICE.IF YOU WANT TO CATCH OVERUNITY PUMP AS MUCH POWER AS YOU CAN FOR EXPERIMENTS. TRANSISTORS IRFP460 OR BETTER IGBT, SEVERAL IN PARALEL 5-10 PEACES LIKE AVISO DID ON PHILIPPINES. RDS(ON) MUST BE VERY VERY LOW. (0.0XX OR 0.000XX OHMS). ТДКС (FLYBACK) PRIMARY SEVERAL WINDINGS HEAVY COOPER WIRE AS ON SCHEMATIC. TESLA DID IT WITH VERY LARGE POWERS ON INPUT. IF YOU CAN PUMP 1KWATT ON INPUT AND TRY TO GET 100KWATT ON OUTPUT. 90% OF ALL ERRORS ARE VERU LOW POWER LEVELS ON INPUT. YOU CAN'T PUT 1 MICROWATT AND GET 1MEGAWATT. USE ABOUT 300-500 WATTS ON INPUT AND TRIM THE OUTPUT FOR MAXIMUM POWER. THIS RED CIRCUIT WORK. IF YOU GOT 5-10KWATT IS ENOUGH FOR WARMING HOME AND HAVE ALWAYS 100o DEGREES BOILING WATER.
RED TOPIC IS HERE
http://realstrannik.ru/forum/39-kapanadze/99249-replika-ot-reda.html#99249
HIS VIDEOS
http://www.youtube.com/watch?v=L-LQcZx4ObI
http://www.youtube.com/watch?v=DCUH5PqrkIU
ONE OF HIS FIRST VIDEOS
http://www.youtube.com/watch?v=GT7QEwz8ORI
ONE MORE THING. IF YOU HAVE MADE TESLA COIL JUST PUT DIODES AND CAPACITORS LIKE IN SCHEMATIC AND TRY.ALSO REMEMBER FEL SCHEMATIC IN HIS 7KWATTS DEVICE HE USED λ/4 BALANCE COIL INSIDE TESLA TRANSFORMER SECONDARY BUT IN OPPOSITE SIDE WINDINGS. MAYBE THIS CAN BE A SUPERB COIL CONFIGURATION. IF YOU ANALIZE RED SCHEMATIC YOU WILL SEE IT IS A PURE TESLA MAGNIFYING TRANSFORMER.
PS. DLLABARRE, NOW YOU HAVE ALL INFO AS YOU ASK. I AM WAITING YOUR VIDEO !! GOOD EXPERIMENTING LUCK !!
FOR MORE INFO LOGIN ON REALSTRANNIK AND ASK RED !!
slapper
Quote from: elementSix on December 25, 2012, 05:25:18 PM
<snip>Have you looked at the RED and Mustafa Schematics??</snip>
Walter Rosenthal commented on a coil circuit he built for Floyd Sweet where Sweet specified that the pulses were to occur at the zero crossing.
Walter Rosenthal comments on Sweet device
So the mustafa device uses a stack of neodymiums.
Interesting.
Thanks.
nap
we are not alone :)
verpies
Quote from: slapper on December 27, 2012, 09:25:51 PM
The diameter of Mustafa's coil indicates that he is not using such strong magnets.
