TK device, TPU.. Only enter if you seek truth. Cause here it is...
Started by elementSix, December 14, 2012, 07:26:31 PM
Сергей В.
Привет всем !!
to Neo-X
Yes. Video and public presentation will not be on any forum. Guess why ??
scratchrobot
Yes. Red used magnets inside of the coil. Magnets are from CB radio startion big antenna holder. Very probably neodymium magnets.
to elementSix
There are many Russian guys on this forum but only few of them made posts
to Magluvin
Mustafs used 2 different power transformers T1 is 270w and T2 is 3kw. You can use big welding transformer as T2. It's not  necessary to have exactly 30v on output. Main thing is Resonance on 50Hz and proper triggering of thyristor when voltage pass through zero. Use high voltage high power thyristor. The speed of componet here play second role.
to verpies
No, Mustafa don't use magnets at all. only power transformers. Look carefully in his schematic. On the first look it's very simple schematic but.......
Including that you verpies have some appropriate equipment and pretty good understanding of physical processes you should start with analizing and researching this schematic. This is an "Anomaly" schematic. Thanks to anomaly we can get OU. You will see yourself than you start pulsing thyristor switch on zero passing envelope.
I hope you will get Overunity and present all on this and many other world Free Energy forums. When you finish maybe i will give you one "Very anomaly"schematic. This schematic is another proof that we don't know anything about very tiny physical processes or in a two words we are out of reality. So maybe you catch a glory like "Anomaly hunter"
Just kidding !! :D
Mustafa topic is here:
http://www.realstrannik.ru/forum/48-temy-freeenergylt-antanasa/101936-mustafa-ustanovka.html
______________________________________________________________________________________
to all: Who will support verpies as a new moderator ? Give him a vote and mail Stefan H. to establish him ! Thanks !!
TO STEFAN H.
ps. My suggestion is to promote verpies as a moderator on this forum and this topic and i gave him my vote
_______________________________________________________________________________________
Magluvin
Quote from: Сергей В. on December 30, 2012, 12:59:35 AM
to Magluvin
Thanks C.  When I saw 3kw from the seconds transformer, it had to be so. And with the first transformer, as much as it takes in input, no sense in using a 3kw transformer there. ;)   Not many of those 3kw transformers laying around. ;)
Mags
Magluvin
From the original scope shot or drawing of when the switching device pulses, at each zero crossing, it is when the output of the second transformer is in high current flow. The switching device loads that current into the cap, and when the switch releases, that cap voltage dumps into the load. Measuring the input of T1 should show a spike at the time of switching also.
I ran it on a sim and was able to produce 2.5 to 3 kw spikes on the load, but the input spikes were around 150 to 200w. There may be something to this.  ;)
Mags
I dip in here occasionally to see what's going on.... interesting stuff. Reminds me of this self-resonant, self-triggering circuit that makes spikes on the zero-crossings.
First image:
Top trace is drain signal from switching mosfet showing the "output" spikes at 200 volts per division; they reach to well over 400 volts. Bottom trace is pickup from a probe _not connected_ to the circuit but connected to a piece of aluminum foil hanging about 20 cm away from the secondary resonator, shown at 20 V/div.
The system detects the secondary's oscillations in the field and makes the spike at the zero-crossing, which is fed to the primary, which stimulates the secondary to oscillate at its resonant frequency.
Second image is the DC input to the system, a little over 50 W. The secondary's output voltage is over 20 kV.... but low current. Still, the peak output power is very high .... unfortunately the _average_ output power doesn't exceed the input.
My system isn't perfectly tuned yet, the pulsing isn't happening exactly at the zero crossing so I'm not getting completely accurate resonant stimulation yet. I think it's now a matter of careful tuning of circuit inductances to get the triggering happening at exactly the right time, and with as sharp/short pulse as possible. This will maximize the VRSWR and the output power.... but I will still be very "shocked" if the output exceeds the input!
Anyhow... sorry if this diversion is too far off the "mark".....  ;)
Carry on......
-TK
elementSix
Has anyone checked out that NULL detector on the previous page thta I posted.  Any thoughts on if thats what is needed to pulse thyritors on Zero Crossing??
Thanks for input Magluvin....
It's a hard translation but, the info on Kapandze setup is good but you need a much  better translater than google..
http://translate.google.com/translate?hl=en&sl=auto&tl=en&u=http%3A%2F%2Fhalerman.narod.ru%2FTTCG%2FKapanadze.htm
