Thanks to ALL for your help!!
Amazing graphene super capacitor!
Started by rukiddingme, December 20, 2012, 06:30:38 PM
Qwert
Quote from: LukeLordOfLight on January 30, 2013, 08:55:01 AM
Does anyone know, what does the chemical reaction in this video? can anyone translate, what`s spoken/written?
http://www.youtube.com/watch?v=iiW3pQ9X7U0&feature=endscreen&NR=1
That guy does not reveal a word about those components or technology. I was learning Russian a while ago and I still understand it somewhat. He says only something like: "look, how science is wonderful and especially Russian science."
You can easily find the patents however the magic juice which is the "activated acid catalyst" sounds a bit vague to me.
QuoteAs still further used herein, the term "activated acid catalyst" refers to an acidic solution of a compound, wherein the solution (typically, but not necessarily aqueous) is subjected to an electromagnetic field, electromagnetic radiation, and/or laser irradiation. Most preferably, the activated acid catalyst comprises an acidic solution that is plasma-activated and/or comprises a compound having the general formula MXOn, wherein M is selected from the group consisting of H, NH4, Na, and K, wherein X is selected from the group consisting of Cl, Br, and I, and wherein n is an integer between 0 and 4, inclusive. It should be noted that the term "activated acid catalyst" also includes one or more oxidizers (typically, but not necessarily in aqueous solution) that were previously subjected to electromagnetic radiation, an electromagnetic field, and/or laser irradiation. Alternatively, and in less preferred aspects, activation using the electromagnetic radiation, electromagnetic field, and/or laser irradiation may replaced by admixing the acid or oxidizer with a penetration enhancer (e.g., compounds and/or mixtures commonly found in lubricating formulations, etc.).
In one preferred aspect of the inventive subject matter, the inventors discovered graphene can be produced from commercially available graphite (e.g., Natural crystalline flake graphite from Superior Graphite Co., 10 S. Riverside Plaza, Chicago, Ill. 60606) using commercially available activated acid catalyst (e.g., Activated Acid Catalyst #3[Plasma-activated hydrochloric acid] from SupraCarbonic, LLC., 348 N. Eckhoff Street, Orange, Calif. 92868, USA). For example, the crystalline flake graphite is granulated to a size between about 0.1 and several millimeter and mixed with the activated acid catalyst in approximately same weight proportions (e.g., 10 gram graphite with 10 ml activated acid catalyst). The so prepared activated graphite is then subjected to heating at a temperature of about 120° C. for up to two minutes (typically less than 40 seconds) to expansion (up to 500-fold in volume). Exemplary electronmicrographs of the so produced material are depicted in FIG. 1A and FIG. 1B at different magnification.
From this patent:
http://www.google.com/patents/US20120237435?dq=ininventor:%22Viktor+I.+Petrik%22&hl=en&sa=X&ei=n5kgUa_NLILXtAaKyYHgBw&ved=0CDkQ6AEwAA
Pirate88179
http://www.nanomagazine.co.uk/index.php?option=com_content&view=article&id=876:making-graphene-oxide-greener
This explains a new way to make GO.  Then, all we need is a DVD disk and a DVD burner.  It might take some time to figure out the mixture ratio but man, this stuff is the future.
The first thing I would do is to hook it to a JT circuit.
I wonder if we can really make this stuff?
Pirate88179
http://hackaday.com/2012/03/20/print-your-own-supercaps/
Print your own supercaps!
This is directly related to the dvd burner process.  This is amazing.
